green scotchbrite *** Please clarify for me***
bjohnson(at)satx.rr.com
PostPosted: Tue Feb 07, 2006 8:38 am    Post subject: green scotchbrite *** Please clarify for me*** Reply with quote
Can someone just cut to the chase and tell me, the 6061t-6 parts on my Sonex
that I have buffed with green scotchbright pad, (it says "type S" on the pad
I cannot read the numbers though) Are those parts trash now??? How will it
screw it up, and is there anything I can do to fix it???? I'm about to
finish riveting the layers of my spar together which were scuffed with this
pad, then painted with NAPA self etching primer....
The 2 documents really say nothing about the above issue....
Thanks!
-Bruce Johnson
moorecomp(at)yahoo.com
PostPosted: Tue Feb 07, 2006 10:37 am    Post subject: green scotchbrite *** Please clarify for me*** Reply with quote
Bruce,
I have poured through the 3M website, and it appears
that the green pads are "scrubbing pads" and the
maroon pads are "abrasive pads". The 7447 maroon pads
are coated with aluminum oxide abrasive and cut the
same as aluminum oxide "sandpaper". The green pads are
not coated and are simply synthetic fiber and are for
cleaning, like a common dish scrubber. That would
explain why Gary had so much "green dust". I have two
links to the 3M website, for the 2 different pads.
Green Scrubbing Pads - http://tinyurl.com/byss3
Maroon Abrasive Pads - http://tinyurl.com/7lnpr
When I worked for a large regional airline, we only
used the 7447 pads.
Hope this clears it up. You should be fine.
Craig Moore
A&P
701 Builder wannabe
it???? I'm about to
issue....
Thanks!
-Bruce Johnson
PostPosted: Tue Feb 07, 2006 1:32 pm    Post subject: green scotchbrite *** Please clarify for me*** Reply with quote
A bit more research I cannot find my exact Scotchbrite on the 3m website, I
got it from a surplus place so God knows if it's still in existence, but the
original post referenced from the "luscomb association" or sum such says
"type s no good" and that's what I actually have. It's more of a
gray-green.. it very well could be gray, in which case I think the abrasive
is "silicon carbide"...
It is definitely NOT the green scrubby clean you sink thing..
K, now I get to research silicon carbide.... or relax and have a homebrew...
Hrm.. have to think on that one.
-Bruce
