WING TIPS
Float Flyr
PostPosted: Sat May 05, 2007 6:24 pm    Post subject: WING TIPS Reply with quote
I notice there are two styles of wing tips being offered at the present time. The classic drooped tips and the Hoerner style.
I have the drooped style on my plane but I was wondering if any one has tried both styles and found any increase in lift of one style over the other. I fly entirely off water on floats ( the only way to go ) and as you expect every bit of lift I can get is appreciated.
C-FINB is ready for flight if the ice will ever melt!.... next week is looking good.
[img]cid:151192002(at)06052007-17F1[/img]
Picture taken last spring.
It was mentioned to me that the drooped tips obscure visibility... Has any one else noticed this?
[img]cid:151192002(at)06052007-17F8[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
 Filesize:  62.97 KB
 Viewed:  543 Time(s)
 Filesize:  19.77 KB
 Viewed:  499 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
xfire
PostPosted: Sun May 06, 2007 6:58 am    Post subject: Re: WING TIPS Reply with quote
Noel,
This is a bit off topic, but have you flown with and without the ventral fin on your fox ? I am thinking of building one for my Avid if it really helps as much as I think it will. Can you get the basic dimensions of the fin for me?
Leonard Perry
Soldotna AK
Avid "C / Mk IV"
582 Full lotus 1260
90% rebuilt
Float Flyr
PostPosted: Sat May 12, 2007 5:27 pm    Post subject: WING TIPS Reply with quote
Leonard:
I'll get you the dimensions and a couple of photos in the morning. Sorry I was away for a while.
I haven't flown without the fin and I do think it would make a considerable difference. There are several planes that use additional fins when the floats are installed and they all work to help the plane to fly straight.
[img]cid:029561201(at)13052007-2309[/img]
Canada
Aerocet 1100s
[quote] --
 Filesize:  19.77 KB
 Viewed:  514 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
akflyer
PostPosted: Sat May 12, 2007 5:54 pm    Post subject: WING TIPS Reply with quote
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
av8rps(at)tznet.com
PostPosted: Mon May 14, 2007 5:33 am    Post subject: WING TIPS Reply with quote
Leonard, I put 1300 hours on three different Avid Flyer models, 90% of those hours on floats. And none of those hours included use of a ventral fin. I never noticed any issues for not having one. The Avids flew beautifully on floats without a ventral fin, and they were extremely maneuverable in all flight modes (fwiw - I did most everything you can do with one on floats too...)
In the last 2 years I have been flying a Kitfox IV-1200 on amphib floats. It has the standard Kitfox ventral fin. It too flies good as a seaplane, but will not slip anywhere near as well as the Avid Flyers did. I suspect that is because of the ventral fin on the Fox, and the fact that the Avid has a "notch" in the back of the fuselage that the Kitfox doesn't. I've not bothered flying it without, but believe if I did it would just take a little adjusting to the increased adverse yaw.
So in my opinion adding a ventral fin to an Avid (or a kitfox for that matter) is probably a little overkill. You won't see significant flight characteristic changes. And the airplane will have adverse yaw either way.
And last but not least, one big detriment of having a ventral fin is when you try to turn the airplane around on a dock, you can't swing the tail over a dock without hitting the ventral fin. Kind of a pain.
Paul Seehafer
Central Wisconsin
Model IV-1200 912ul on Aerocet amphibs Avid A-model 532 Rotax on Avid Floats
IVO prop
[img]cid:005001c7962c$390dc680$0442aa42(at)pc1[/img][img]cid:005101c7962c$39128170$0442aa42(at)pc1[/img]
[quote] --
 Filesize:  99.69 KB
 Viewed:  563 Time(s)
 Filesize:  63.79 KB
 Viewed:  555 Time(s)
