Float Flyr
Posted: Sat May 05, 2007 6:12 am Post subject: Homebuilt-List Digest: 1 Msgs - 05/04/07 |
First thing you will need is a three volt power converter. Depending on the distance between your lights and the power supply you may find you will have to use ridiculously large wire. Wire the LEDs in parallel. You may have to wire a 300Ohm resistor in series with each LED to keep the brightness down and the life up.
What I would consider doing is making a larger Water proof battery boxes with three or four NiMh batteries wired in parallel (single battery lamps) then if there isn't enough sunlight to power the lamps through the night on one battery you can clip on the booster pack. You may have to recharge that pack one once every other week or so.
Remember to use NiMh batteries as they are more resistant to a phenomenon called memory effect. NiCad batteries are cheaper but you probably will end up with problems before too long. If your lights now have the NiCad batteries try swapping them out for the NiMh ones that may fix your problem.
[img]cid:698121114(at)05052007-17E3[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
| | - The Matronics Homebuilt-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Homebuilt-List |
19.77 KB |
772 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
