aadamson(at)highrf.com Guest
Posted: Fri May 04, 2007 11:17 am Post subject: Stuck looking for a switch |
I'd like to use an Off-(ON) type toggle switch for a start switch.... BUT,
I'd like to use it with a "Switch Guard". So, ok, that seems pretty
straight forward... However, I ordered a switch guard and noticed that it
has a tab that mates to the groove in the switch to prevent rotation. The
tab is on the bottom of the hole when the switch guard is oriented correctly
(flip up to access). Good so far, right....
Wrong, all of the Momentary switches that I've been able to look at have the
groove *UP" when positioned so that the momentary position is UP... Exactly
opposite of what I need.
While the above may not be a very good description, I thought I'd post this
to see if anyone had an idea of what switch or other I might utilize to
correct this problem. Obviously, I can grind the tab away and use star
washers to prevent rotation, but I'd like to keep it locked together with
the tab and groove if I can...
Thanks in advance,
Alan
john(at)ballofshame.com Guest
Posted: Fri May 04, 2007 11:31 am Post subject: Stuck looking for a switch |
Well, if you don't mind doing without guard, digikey has a LOT of switch
options. There's one that does (On-Mom) with a keylock handle (i.e. you
have to pull the handle out to get it to the momentary state). It's just
as good as a guard and takes up less space. Probably looks nicer too.
Give a look at what they have, anyway.
-John
www.ballofshame.com
<aadamson(at)highrf.com>
correctly
the
Exactly
this
Thanks in advance,
Alan
Posted: Fri May 04, 2007 11:49 am Post subject: Stuck looking for a switch |
John, yep you are right, however the problem with a starter, it doesn't like
to be switched on all the time so it needs to be a momentary in the real
sense of the word, not lockable. So the guard is used just to make sure it
doesn't get lifted when you are reaching around the panel, in the bumps
Alan
rjquillin(at)gmail.com Guest
Posted: Fri May 04, 2007 12:09 pm Post subject: Stuck looking for a switch |
At 12:15 5/4/2007, you wrote:
| Quote: | Wrong, all of the Momentary switches that I've been able to look at have the
Without digging through all my notes, I seem to recall the guard was
available in either orientation.
Might be worth checking a bit further.
Ron Q.
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Fri May 04, 2007 12:40 pm Post subject: Stuck looking for a switch |
I think Alan has a very valid point, something I am thinking of using also:
for anyone who has had an engine failure (due to fuel starvation) to have a
starter switch with an 'on' position helps you free up a hand when you are
trying to fly the plane with one hand, and try all alternatives to get the
thing started again (pump primer, pump the throttle etc) with the other.
John
Posted: Fri May 04, 2007 12:52 pm Post subject: Stuck looking for a switch |
Ding, ding, ding, you get the prize.... Thanks so much, looks like I need an
MS25224-3 instead of a -1 (which I believe I have)...
Data here...
http://www.eatonelectrical.com/html/VCBU/commcat2/guards.pdf
Thanks again, that was a great help!
Alan
Posted: Fri May 04, 2007 2:13 pm Post subject: Stuck looking for a switch |
I see that you found the solution. Just to clear up the switch, though.
I believe the switch is momentary...it's just that you have to unlock it
to get it in the momentary position. When you let go, it snaps back down
and relocks.
-John
www.ballofshame.com
like
it
Alan
khorton01(at)rogers.com Guest
Posted: Fri May 04, 2007 4:49 pm Post subject: Stuck looking for a switch |
I had a similar problem. I couldn't find a quick source to get the
correct switch guard, so I filed off the tab on the guard so I could
put it on in the other orientation. Then I drilled a small hole
through the metal base near the hinge, and bolted it in place on the
panel with a 2-56 bolt and nut. That keeps it from rotating, and is
not visible when the guard is down.
Kevin Horton
I need an
Data here...
Alan
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Fri May 04, 2007 5:18 pm Post subject: Stuck looking for a switch |
Alan,
I was assuming "UP" would be the logical direction for start...
Bret Smith
RV-9A (91314)
Mineral Bluff, GA
www.FlightInnovations.com
_________________ Bret Smith
RV-9A (Emp) |
Posted: Fri May 04, 2007 7:30 pm Post subject: Stuck looking for a switch |
Kevin, you read my mind... I may do that exact same thing... We'll see...
Alan
Yep, that's correct, however with the little tab down to allow the guard to
flip up, that is exactly 180 degrees opposite of what you need with the -1
version of the guard. But we've beat this one dead and I know the
solution... Actually 2 of them
Alan
schamber(at)glasgow-ky.co Guest
Posted: Fri May 04, 2007 7:46 pm Post subject: Stuck looking for a switch |
I had the same issue on a couple of switches, I just milled another slot in
the threaded part of the switch 180 degrees from the original.
Sam Chambers
Glasgow, KY
Long-EZ N775AM
