Craymondw(at)aol.com Guest
Posted: Fri May 04, 2007 7:06 am Post subject: Check your Cleveland brakes |
About 100 hours after installing a brand new Cleveland brake caliber assembly the fluid drained out. I discovered the piston was installed backwards and the "O" ring was past the piston barrel allowing the fluid to drain out. About a hundred hours after that incident a master cylinder blew out of the very bottom. I plugged that hole with mixture of epoxy and Mill Fiber.
See what's free at AOL.com.
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
