EFIS
hansriet
PostPosted: Thu May 03, 2007 1:12 pm    Post subject: EFIS Reply with quote
Is there anybody who is going to install or who installed already an EFIS (like the Dynon) without an analogue backup of primairy flight instruments?
I see the advantage (financially as well as for panel real estate) of having an EFIS that's all in one and that includes an HSI. But if you have to install analogue instruments as well that kind of defeats the purpose, doesn't it?
I would like to hear your thoughts on this.
Hans van Riet
dredmoody(at)cox.net
PostPosted: Thu May 03, 2007 1:49 pm    Post subject: EFIS Reply with quote
Hello Hans,
My 601XL is not flying yet...... it will probably fly late this year, so the question and my answer are still academic rather than experience based.
With that disclaimer, I am using two AF-3400 units from Advanced Flight Systems; one is the EFIS and the other is the EIS. I have put a steam gauge ASI in my panel (2.25" from UMA) as a backup. I have also installed a Tiny Tach to backup the Tach display. My gps provides a backup display of ALT.
I figure that if the EFIS goes dark on me, I want Tach and ASI to get down safely with confidence. If the aircraft electrical system is still working and the weather is good I may even decide to complete the flight to the original destination with the ALT info from the gps.
I am not planning on adding backup gyro instruments since the plane is for VFR Cross Country. If you plan to certify yours for IFR, you may need the back up gyros.
Dred
Hans van Riet
http://forums.matronics.com/viewtopic.php?p=110675#110675
larry(at)macsmachine.com
PostPosted: Thu May 03, 2007 2:03 pm    Post subject: EFIS Reply with quote
Hans,
You make a very good point. For instrument flying the argument wouldn’t
apply, but as a VFR experimental, you could very well install an Engine
Information System and an EFIS as your primary instrument groups and
forgo all but perhaps a compass and a lift reserve indicator. The weak
link here is obvious that any one component can fail all and you’d be
looking at possibly a larger replacement or repair cost. If I had
do-overs, I’d have left all the “expensive not so durable round gages
off the panel. My EIS has been the easiest and least costly item to
install. The tachometer was replaced once at $100.00, the electric T&B
has been in and out twice at $250.00, so an EFIS is looking pretty good.
Larry McFarland 601HDS at www.macsmachine.com <http://www.macsmachine.com/>
Hans van Riet
MaxNr(at)aol.com
PostPosted: Thu May 03, 2007 5:49 pm    Post subject: EFIS Reply with quote
I am interested in the DYNON FlightDEK 180 but the Stratomaster Enigma is coming on strong. Because my project is day/night VFR I don't realy need backups. But I do want back up oil pressure, ASI and altimeter steam gauges with a simple glue on skid indicator. These would be the cheapest, non TSO'ed used gauges that I can find. My reasoning is I would have dispatch capability if the Dynon went black away from home. Gauges would be on the copilot's side.
The last year and half before retirement was with a Honeywell glass cockpit and I was the grumpy old ***** that only watched the standby steam gauges during critical stages of flight, then transitioned to the glass on climb out. I got more accepting after about 600-800 hours.
My hope is that there is a lot of chatter about this because I respect all your opinions and my mind is still open.
Bob Dingley
601XL/Lyc
See what's free at http://www.aol.com. [quote][b]
craig(at)craigandjean.com
PostPosted: Thu May 03, 2007 6:27 pm    Post subject: EFIS Reply with quote
I have an Enigma but I am not flying yet. I'm backing it up with an MGL
Flight II. I bought a glass panel to get away from mechanical gauges, why
would I want them for back-up? Why have back-ups which are *less* reliable
than what they are backing-up? Electricity? The Flight II will run on a 9
volt battery for two+ hours and the shelf life of an alkaline battery is 5
years. And in reality the 9 volt battery is a back-up to the back-up battery
for the Enigma.
www.mglavionics.co.za/flight2.html
In a 3.5 inch hole the Flight II gives you:
* Altimeter
* Airspeed indicator
* Analog VSI
* Digital VSI
* Density altimeter
* True airspeed
and a lot more.
If you want back-up engine instruments add an MGL E1:
www.mglavionics.co.za/Docs/e1.pdf
In another 3.5 inch hole you gain:
* RPM with digital and analog readout.
* Programmable engine hobbs meter and running timer (flight timer).
* Up to four thermocouple channels for EGT and CHT probes, fully
programmable.
* A water temperature or oil temperature monitor.
* Oil pressure monitor.
Chris Smith flies his Cleanex (Corvair-powered Sonex) with nothing but a
Flight II and an E1.
Also, don't forget that if you have a Garmin 296/396/496 it will run on its
internal battery for hours and can provide basic attitude information. But
it can't provide air speed.
-- Craig
 Filesize:  31.65 KB
 Viewed:  812 Time(s)
p.mulwitz(at)worldnet.att
PostPosted: Thu May 03, 2007 6:45 pm    Post subject: EFIS Reply with quote
Hi Hans,
My plan is to install a single Dynon combined EFIS/EIS. The only
other flight instrument I have is a lift reserve indicator I made
while waiting for my wing kit to arrive. For radios, I will have
some sort of (portable, battery powered?) GPS along with a Comm
(NAV?) and transponder.
The GPS provides a reasonable backup for the EFIS. I consider
neither one necessary unless I screw up and find myself in bad
weather where I must fly on the gauges. For most VFR flights I don't
require any instruments at all - except for navigation in unknown territory.
I will be operating with Sport Pilot limitations, so only VFR day
operations are planned. Also, I had the benefit of a really good
instructor for night flying. He took me up one evening (in a 172XP)
and we did circuits and bumps for an hour or two. We started at dusk
and went well into total darkness. The only lights in use were the
navigation lights required to keep others from hitting us. I learned
to handle all the necessary controls by touch and to control the
engine, prop, and airspeed by just sound and the nose position
compared to the horizon. Once you know how to fly with a totally
black cockpit, you don't forget. If you haven't yet learned to fly
like this, then you probably should include a backup airspeed
indicator and perhaps an altimeter. If you have a GPS, it can give
you fine altitude information, but the speed it gives is only ground speed.
If I were planning to fly true IFR, then I would include a backup
TBI, airspeed, and altimeter. I know needle/ball and airspeed flying
is hard work, but if you consider yourself competent to fly IFR then
you should be able to fly on this level of minimum panel in the rare
case when your EFIS turns toes up. If not, some remedial training is in order.
Good luck,
Paul
XL fuselage
instruments?
Hans van Riet
secatur
PostPosted: Thu May 03, 2007 11:40 pm    Post subject: Re: EFIS Reply with quote
As previously Posted
Enigma EFIS/EIS/GPS tec.
XCom Radio/Intercom
Electric Flaps/Trim
Room for Xponder and MGL Flight II if required
 Filesize:  191.24 KB
 Viewed:  779 Time(s)
 Filesize:  94.21 KB
 Viewed:  781 Time(s)
david_a_g_johnson(at)btin
PostPosted: Fri May 04, 2007 1:26 am    Post subject: EFIS Reply with quote
I'm not flying yet, so I can't speak from experience!
I have installed the Dynon D100 EFIS and D120 EMS. The EFIS has a battery
backup, so if it all goes dark, I should have at least the flight
instruments.
I ave also a magnetic compass and ASI and Altimeter (both 2.25", so don't
take up much space).
Here in the UK we are limited to daytime/VFR anyway, so I always have the
option of looking outside to make sure I'm the right way up and above
ground.
Dave Johnson
601XL Jab.3300
dbortol
PostPosted: Fri May 04, 2007 3:34 am    Post subject: EFIS Reply with quote
My plane will fly in a year not yet determined. I'm planning to equip it for night VFR and OTT. My current plan is to use a Dynon D100 as the primary instrument, backed up by a lift reserve indicator, electric T&B, and GPS. My thought is that if looking outside isn't enough in the circumstances, I would maintain safe airspeed using the LRI, altitude using GPS, and wings level from the T&B. It would be high stress flying!
Dino Bortolin
On 5/3/07, hansriet <hansinla(at)mac.com (hansinla(at)mac.com)> wrote:[quote] --> Zenith-List message posted by: "hansriet" <hansinla(at)mac.com (hansinla(at)mac.com)>
Hans van Riet
fderfler(at)gmail.com
PostPosted: Fri May 04, 2007 5:29 am    Post subject: EFIS Reply with quote
I fly a 601XL with a Dynon D-180 on the left side of the panel and a Garmin 396 in the middle. I love everything about the setup (well, except the price of the backup battery for the Dynon).
My mistake was in not putting a D-10A or some other form of attitude indicator on the co-pilot's side. Motivated by a sad case of the "cheaps" I assumed that the screen on the D-180 on the left would be big enough to allow a pilot on the right side to use it. Wrongo. My pilot friends in the right seat need something to look at. Sporty's backup AI would be an option and it would give the "backup". But, for the difference in price between the Sporty's AI and a separate D-10A the D-10A provides a much more usuable picture with more information and independent backup that gives what one person on this thread called "dispatch capability." (Assuming, I guess, a separate pitot).
So, don't make my mistake. Put two screens in if you will ever have a pilot in the right seat.
Frank Derfler
See my views and reviews at www.derfler.biz
See my information for pilots at www.flyinflorida.com
ccwacker(at)HOTMAIL.COM
PostPosted: Fri May 04, 2007 5:46 am    Post subject: EFIS Reply with quote
I have a Dynon D-100 and D-120. I also have installed a TruTrak Autopilot
that has a horizon and DG, this along with a small altimeter and ASI give m
a good backup. In addition the GPS can be of help. Is this overkill?
Probably. My main backup is this thing called a compass and a map.
Chuck Wacker
N601CW, quick build
[quote]From: "Dave Johnson" <david_a_g_johnson(at)btinternet.com>
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Subject: Re: EFIS
Date: Fri, 4 May 2007 10:25:30 +0100
instruments.
ground.
Dave Johnson
601XL Jab.3300
