MJKTuck(at)cs.com Guest
Posted: Wed May 02, 2007 5:36 pm Post subject: Seat Thoughts |
Hi Folks,
My own experience of my seats is that when in the seated position for an hour or so there is a definite pressure point right on my butt cheeks mainly I think because my foam seat isn't quite thick enough or is too soft. I end up feeling the flat floor of the glassed foam inserts covering the pushrod tunnel.
I want to do it again as part of a refurb and think the best thing to use is to determine what shape I would need for total (wrap-around) support. Isn't there some way of sitting on a bag of polystyrene beads and then sucking all the air out? I believe race car drivers custom fit their seats somehow this way. Anyone know of a kit or something?
Once you have the basic shape you could get a better idea of what the final shape ought to be. My guess is that given the posture you end up with in a Europa there would be a lot more foam in the lumbar area (and below) as well as under the legs.
My 2c worth.
Martin Tuck
Europa N152MT
Wichita, Kansas [quote][b]
n100rh(at)sbcglobal.net Guest
Posted: Wed May 02, 2007 9:04 pm Post subject: Seat Thoughts |
Martin,
I made a seat for a f.ford years ago by sitting on a garbage bag with
two part foam mix in it. The trick is to be in the position you want to
be in as the mix makes the seat around you. After making the mold, I
glassed it to make a neater package. Interesting project.
Ralph
MJKTuck(at)cs.com wrote:
| Quote: | Hi Folks,
My 2c worth.
Martin Tuck
Europa N152MT
Wichita, Kansas
kheindl(at)msn.com Guest
Posted: Thu May 03, 2007 5:06 am Post subject: Seat Thoughts |
Martin,
I had the same problem and solved it with a short term, very low cost,
solution, which ended up being a longterm solution:
I asked a local upholsterer to make me a large cushion out of memory foam,
about 3 inches thick.
It was really meant for my passengers, but now I use it all the time myself.
I just lay it on top of my sculpted seat, and it feels like I am sitting on
a cloud. The pressure points are compressed to nothing, so there is
virtually no loss of headroom ( I am 6'2"), and it molds itself around your
behind and under your thighs. I can sit there all day without any
discomfort.
Karl
| Quote: | From: MJKTuck(at)cs.com
Reply-To: europa-list(at)matronics.com
Subject: Seat Thoughts
Date: Wed, 2 May 2007 21:33:54 EDT
Hi Folks,
hour
up
tunnel.
is
all the
way.
well as
under the legs.
My 2c worth.
Martin Tuck
Europa N152MT
Wichita, Kansas
Reserve your place in history - Email Britain!
http://www.emailbritain.co.uk/
ami(at)mcfadyean.freeserv Guest
Posted: Thu May 03, 2007 1:54 pm Post subject: Seat Thoughts |
Martin,
Your last three words ("under the legs") is the key to it.
By putting support under the legs, weight is taken off the pressure points under the 'butt'.
Seats forms moulded intimately from expanding foam are fine for racing cars, where you need to be held firmly against the chassis for relatively short periods. In an aeroplane, there is a need to be able to squirm around abit and shift weight to a more comfortable position on a long flight. A tight fitting seat (despite feeling comfortable initially) prevents this.
Duncan McF.
Posted: Thu May 03, 2007 2:59 pm Post subject: Seat Thoughts |
Duncan, I agree with you 100%. A 'hardwired' seat is not a good idea. Also I
tried this foam wedge in the lower back that others are talking about. I
found it to be irritating as it reduces your seat area.
I also like to be able to move around from time to time.
Karl
[quote]From: "Duncan & Ami McFadyean" <ami(at)mcfadyean.freeserve.co.uk>
Subject: Re: Seat Thoughts
Date: Thu, 3 May 2007 22:51:35 +0100
Martin,
under the 'butt'.
Duncan McF.
