Check out some boring video
WillUribe(at)aol.com
PostPosted: Wed May 02, 2007 5:37 pm    Post subject: Check out some boring video Reply with quote
Click here: Kolb FireStar II - Google Video
See what's free at AOL.com.
possums(at)bellsouth.net
PostPosted: Wed May 02, 2007 6:20 pm    Post subject: Check out some boring video Reply with quote
How'd you get the vibration out ? [quote][b]
PostPosted: Thu May 03, 2007 6:37 am    Post subject: Check out some boring video Reply with quote
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of possums
Sent: Wednesday, May 02, 2007 8:23 PM
Subject: Re: Check out some boring video
I did nothing, I guess it has more to do with the camcorder's image stabilizer function.
jhankin(at)planters.net
PostPosted: Thu May 03, 2007 7:36 am    Post subject: Check out some boring video Reply with quote
ÿþ<!DOCTYPE HTML PUBLIC 2-//W3C//DTD HTML 4.0 Transitional//EN 2> <HTML><HEAD> <META http-equiv=Content-Type content= 2text/html; charset=unicode 2> <META content= 2MSHTML 6.00.6000.16414 2 name=GENERATOR> <STYLE></STYLE> </HEAD> <BODY bgColor=#00ffff> <DIV><STRONG>Please post the web address.&nbsp;<EM>&nbsp;I &nbsp;have to copy and paste the address.&nbsp; My computer has stopped letting my click on a address.&nbsp; Anyone know how I can correct this?</EM></STRONG></DIV> <DIV><STRONG><EM></EM></STRONG>&nbsp;</DIV> <DIV><STRONG>Jimmy Hankinson<BR>912-863-7384<BR>Firefly #035, (N6007L)<BR>JYL (Sylvania&nbsp;Ga.)<BR>Pegasus Field (Home)<BR>2000 Feet X 100 Feet- Grass<BR>Rocky Ford, Georgia<BR>Do Not Archive</STRONG></DIV></BODY></HTML> [quote][b]
GeoR38
PostPosted: Thu May 03, 2007 10:16 am    Post subject: Check out some boring video Reply with quote
In a message dated 5/2/2007 10:21:20 P.M. Eastern Daylight Time, possums(at)bellsouth.net writes:
Neeeeto!.............especially for a challenged pilot like myelf having not flown in
my wonderful KX for 2 years since moving to Florida
question.... i noticed there was a crosswind from your left, yet you used a right pattern..... also where was that....seemed a little like El PASO OR  New Mexico.
George Randolph
George Randolph
Firestar driver, The Villages, fl
Paul Petty
PostPosted: Thu May 03, 2007 11:32 am    Post subject: Re: Check out some boring video Reply with quote
Great stuff Will! Where is that airport and how long is that runway?
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
PostPosted: Thu May 03, 2007 1:30 pm    Post subject: Check out some boring video Reply with quote
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of GeoR38(at)aol.com
Sent: Thursday, May 03, 2007 12:15 PM
Subject: Re: Check out some boring video question.... i noticed there was a crosswind from your left, yet you used a right pattern..... also where was that....seemed a little like El PASO OR  New Mexico.
Video was taken in El Paso, TX and at this airport ultralights and gliders use a north side traffic pattern. GA use a south side traffic pattern.
PostPosted: Thu May 03, 2007 3:05 pm    Post subject: Check out some boring video Reply with quote
At 10:36 AM 5/3/2007, you wrote:
From: owner-kolb-list-server(at)matronics.com [ mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of possums
Just wondered....I've got the image stabilizer on two different cameras.
One digital one Hi-8
Never could get the shaking out when I connected either one of them to
the airframe, or even the wing unless I practically turned the engine off.
My head acts as a perfect shock absorber, but it would be nice to
not have to wear the camera. I like the idea of having it look over your shoulder
and being able to click it on and off when something interesting happens.
Nice Job.
Richard Pike
PostPosted: Thu May 03, 2007 5:57 pm    Post subject: Check out some boring video Reply with quote
Years ago, shot video all fall from my Hummer, used a camera carrier that suspended the camera from bungee cords. Made a cradle that attached to the camera using the 1/4" mount in the base, curved around above the camera. Attached to the airframe was a pivoting bracket that pointed forward (default) but could be turned from side to side, And since the camera was hanging from bungees off that bracket (about 2" between camera bracket and support bracket) you could depress or elevate the camera as well. No vibration, worked great. It sat out in the free air about 8" to the left of the cockpit where I could aim it with my left hand, or turn it loose and it just pointed straight ahead.
These were the early days of VCR's, "portable" meant using a huge RCA VCR hanging from the main tube in it's own harness to keep it from being vibrated to death by the mighty Rotax 277, powered it off the 12V system in the aircraft, with a huge coax connector to the big, old fashioned VCR camera which was as big as my arm. Heavy too, that's probably why it didn't vibrate, too much mass. Color was crummy, but had a lot of fun, dubbed the whole thing to music.
Thinking about doing it again this fall with the MKIII, could make a bracket that uses the 3/16" bolt hole in the fuselage side by my left elbow, and clamp a top mount to the cage right by the top seat belt mount. Use the half doors and be all set. My old Sony Handycam only weighs a tenth of what that original mess weighed, will probably have to ballast it to keep the vibration out.
Richard Pike
MKIII N420P (42OldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Thu May 03, 2007 7:01 pm    Post subject: Check out some boring video Reply with quote
I did that too, Big camera, bungee cords, springy steel plate
rivet mounted on the side of my 1983 CGS Hawk. BTW that was
the top of the line 1983 utralight, ailerons, flaps, etc.
Heck ....back then a double surface wing was a big thing.
But still, the vibrations made the video unwatchable for most
anybody but me. The new stabilizer chips take out the big jerky moves,
but don't seem to do much for the little engine vibrations. I have remotes
to turn my cameras on an off, so I don't need to have them wasting memory
or film even when they are out on the wings or on the tail.
If anybody could really solve the vibration problem, we all could do
amazing videos ...I mean the 5 minutes you get in the average 3 hour flight.
Here is what my old HI-8 set up off looks like, the new digital is much smaller
and much cleaner. I got a little box to convert the VHS/Hi-8 stuff to digital
so I can load it on Goggle. I ought to send "Larry out west"?" my old system
and let him shoot some stuff to entertain us. I'll ever convert it
and load it on
Goggle for him.
Hi-8/VHS converted - "Old"
http://video.google.com/videoplay?docid=-9177096133625180462&hl=en
Digital "mostly"
http://video.google.com/videoplay?docid=-8558932262133094065&hl=en
 Filesize:  41.63 KB
 Viewed:  566 Time(s)
 Filesize:  43.93 KB
 Viewed:  561 Time(s)
 Filesize:  58.48 KB
 Viewed:  561 Time(s)
olendorf
PostPosted: Fri May 04, 2007 4:57 am    Post subject: Re: Check out some boring video Reply with quote
I have used this software to remove the shake from videos. You need to get the videos to your pc first. Then run in through VirtualDub with the Deshaker plug in. It is a little tricky but it can save videos that are just too shaky to watch. I almost deleted 2 videos I had made of my kids first wakeboarding attemps because they are so bad. But after deshaking them they were good enough to keep, pretty good actually.
Here is the plug-in;
http://www.guthspot.se/video/deshaker.htm
How to use Deshaker guide:
http://www.sundancemediagroup.com/articles/deshaker_guide.htm
Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/
JetPilot
PostPosted: Fri May 04, 2007 7:23 am    Post subject: Re: Check out some boring video Reply with quote
The video was great, keep on filming, nothing boring about watching a Kolb fly !
Mike
Kolb MK-III Xtra, 912-S
lcottrell
PostPosted: Sat May 05, 2007 9:25 am    Post subject: Check out some boring video Reply with quote
system
and load it on
Goggle for him.
Digital "mostly"
So do you need my address???? I would even settle for information on your
new set up, it would save me the learning curve.
Larry, Oregon, currently in San Antonio.
