scottmschmidt(at)yahoo.co Guest
Posted: Mon Apr 30, 2007 9:37 am Post subject: High Oil Temps |
Need some advise. On Saturday I loaded up the plane and went to Moab UT for the day (about an hour flight). We hung out for the day, went to the car show down there, rented a Jeep and did a couple trials and then headed home.
We left around 8:00pm. The outside air temp was around 74 when we took off. Before starting my engine the oil temp was 101 F. I took off flew south over Moab, then down on the Colorado River and began climbing to the north. While climbing I noticed my oil temps at 220 F. I have never seen them that high and I was right over the airport so I landed and thought my ducting had fallen off.
I took off the cowl, and everything looked perfect. Thought a bird or something else might have gone down the ducting and covered the oil cooler but it looked perfect when I checked that. Tim took my call late at night while he was watching a movie just so I could have a second head thinking about anything else I might have missed.
I put the cowling back on and took off by myself and flew around. I really had to climb slow to get it to 200 F but everything looked normal. So the four of us loaded up and we were off. I typically climb around 100 to 105. On climb out the temps went to around 205 and maxed at 210. Once I was at 9500 they went to 195 to 200 and then seemed to stabilize around 190. These still seem higher than I have had in the past. I am use to temps around 170 to 180.
I typically just fly with my wife and I and most the flying has been in the winter. My CHT's and EGT's look the same as they normally did, only my oil temps have changed. This was the warmest weather I have flown in with 4 people but I was still climbing at 105 knots. Sure my climb rate may be lower but the cooling should be the same. All I can think of is the angle of attack with 4 people changes the cooling rate into the oil cooler.
Do many of you in the south go above 200 F very often? Where does your oil temp run with 4 people with an OAT of 70 and power settings around 19.5 and 2400?
I will grab a few more test passengers and go do some more work before adding a larger oil cooler or cooling ducts in the side like others.
Scott Schmidt
scottmschmidt(at)yahoo.com
Deems Davis
Posted: Mon Apr 30, 2007 10:16 am Post subject: High Oil Temps |
"Scott, I will be very interested in your progress on this issue. I live
in Phoenix, and high temperatures is a fact of life. talking w/ fellows
(at) EAA chpt mtgs. reveals that the RV6,7,8" guys all buy the biggest and
most efficient oil cooler they can. I was told of one that was 20% more
efficient than the one that Van's ships, I don't recall it's name/number
but could find out if you need the info. Some have had success mounting
the oil cooler directly behind the #4 cyl on the baffling as opposed to
the firewall. I doubt there's room enough on the -10 for this to work.
Here's a quote from my Lycoming Operators Manual O-540,IO-540 Series:
Section 3 page 3-9 /" Oil temperature: The maximum permissible oil
temperature is 245 deg F (118C). for maximum engine life, desired oil
temperature should be maintained between 165 deg F (73.8C) and 200F
(93.3C) in level flight cruise conditions ".
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Scott Schmidt wrote:
| Quote: | Need some advise.
Rick S.
Posted: Mon Apr 30, 2007 10:57 am Post subject: High Oil Temps |
I have the same interest in this as Deems does. At OSH last year John Cox in a very fatherly and convicted manner told me I would have to deal with this problem being located in the Southwest, Las Vegas to be exact and similar if not a bit cooler than Deems in Phoenix. John reminded me that the RV-10 was designed and tested in Oregon, in obviously cooler temps. Deems has the James cowl so it will be interesting to see his performance in the cooling department. I have the stock Van's supplied cooler which will be changed if there is a better model out there. When Russ Daves was out here last year Bob Kaufmann, John Erickson and myself were lucky to get some -10 stick time. Russ asked John at one point to lower the nose to keep the temps down on a few of the touch and goes, I didn't do any take offs or landings but provided the ballast in the back seat. Hopefully I will feel better (worked the night shift then off to the airport early) on his next trip to get some worthwhile stick time short of flying us to and from the practice area and a few steep turns.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
mritter509(at)msn.com Guest
Posted: Mon Apr 30, 2007 10:58 am Post subject: High Oil Temps |
Scott,
Flew to Baja recently with two passengers and about 60 pounds of bags.
OAT's were well into the 70's and lower 80's on climb outs. On climb out
(1,000+ fpm) oil temp would climb to 205. It came down to 185 as soon as I
lowered the nose once reaching cruising altitude.
I generally cruise at 65% - 70% of power for a reference. On hot days (75+)
before I added the louvers on the bottom cowl the oil temp was in the
210-212 range in cruise and 220+ when climbing. With the louvers I'm seeing
185. Even with the louvers I have to reduce power and climb angle on hot
hot days to keep the oil temp below 200. Before adding the louvers my cowl
was extremely hot to the touch and now its just warm. I think having a
larger opening in the bottom of the cowl for the heat to exit helped lower
the oil temp.
Bracing for when it really gets hot here in Texas.
Mark (N410MR)
| Quote: | From: Scott Schmidt <scottmschmidt(at)yahoo.com>
To: RV-10 List <rv10-list(at)matronics.com>
Subject: High Oil Temps
Date: Mon, 30 Apr 2007 10:36:30 -0700 (PDT)
home.
around 170 to 180.
2400?
Scott Schmidt
Need a break? Find your escape route with Live Search Maps.
http://maps.live.com/default.aspx?ss=Restaurants~Hotels~Amusement%20Park&cp=33.832922~-117.915659&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=1118863&encType=1&FORM=MGAC01
Tim Olson
Posted: Mon Apr 30, 2007 11:03 am Post subject: High Oil Temps |
This one will be interesting to follow. It's a tough spot to be in...
not high enough to seriously scare you, but not nearly as low as
normal. Makes it hard to figure out what to do.
For what it's worth, I seem to hold in the 165-180 range in the winters,
and pretty much almost always about 185 in the summers here. But,
I also never saw any alarming oil temps when we were on any of our
trips, even though we did fly on some hot days....some of that was
even in the SouthWest, and NorthWest in the summer, and some was on
extended climbs.
Looking into some of the logs that I downloaded from my EIS,
I do see that on the trip to Oregon, (hot), it looks like my
highest Oil Temp was 197, and that was just a couple of log
entries and then it was back in the 180's. Then looking at
another trip last spring/summer on a hot day (I think that
was the Yellowstone trip), I do see that on one climbout
I hit 208. That same flight stabilized in the low to mid
190's. But, keep in mind from Deem's post that the
recommended specs 165-200 in level flight cruise.....so
if you peak out on climb at something higher but still
well under the 245 degree range, I don't know that I'd worry.
I guess I myself would reduce that limit from 245 to maybe
220 to get an earlier warning, and maybe have my Chelton EIS
limit programmed to go yellow at 200 and red at 220. Just
like the CHT limit is officially 500, but you'd be nuts to
run that high.....so my yellow is 400 and red is 415 or
something like that.
Again though, when I pour over my logs, I don't see anything
that leads me to believe that we have anything to worry
about from a design perspective. The oil temps are usually
towards the middle end of that temp range and I'd pretty
much call them "perfect". I wouldn't want it to run any
cooler, and except for those brief peaks during climbs where
I topped 200, if you look at my x/c line graph, it's almost
never anywhere near 200.
Keep watching it for some flights and see how it goes.
Since you have a Chelton system, I know you can use EGview,
which is FANTASTIC software....download your logs from all
of your flights for a while and you can check out what the
temps were all the time. It's a great tool for just
this type of thing. It also includes a GAMI tool so you
can flow match your injectors and it will analyze to show
you the spread. Good stuff!
| Quote: | Need some advise. On Saturday I loaded up the plane and went to Moab UT
headed home.
the oil cooler.
19.5 and 2400?
Scott Schmidt
pilotdds(at)aol.com Guest
Posted: Mon Apr 30, 2007 11:26 am Post subject: High Oil Temps |
My temps ran about 175 in the winter.I became alarmed when an oat of 85 and a fully loaded airplane yielded cruise oil temps of 207.I installed the oil cooler from airflow systems and saw an 8 degree drop as well as much quicker cooling when leveling out for cruise.I did accurate side by side testing and saw a noteworthy improvment.It frequently excedes 100 here in the summer.Intallation is simple.
Tim Olson
Posted: Mon Apr 30, 2007 11:31 am Post subject: High Oil Temps |
Before I get jumped, I'd like to add: You guys in the Southwest
and Texas may want to do something to yours, just because you
spend a majority of your time in hot conditions. If you're
someone who only visits those areas, just using good technique
like dropping the nose for a faster climb speed might be
all it will take to keep you happy. I'd caution the more
northerly builder against going too far to cool things unnecessarily
because you do want good warm oil in flight, and if you cool it
too far, you're going to have to make accomodations for when
you fly in your cooler or more normal lower temps. You don't
want your oil temps too low, and from what I see, I
more often come close to the low end of the 165-200 range
than I do the high end. Your mileage will vary depending on
your geography. If I lived in the desert and thought I could
survive there, I would probably increase my oil cooling but
I'd carry a plate or put on adjustable louvres on my cooler...or
maybe even add cowl exit area and then add cowl flaps.
Tim Olson wrote:
extended climbs.
> then headed home.
> so I landed and thought my ducting had fallen off. I took off the
> thinking about anything else I might have missed. I put the cowling
> use to temps around 170 to 180. I typically just fly with my wife and
> Scott Schmidt
BPA(at)bpaengines.com Guest
Posted: Mon Apr 30, 2007 11:36 am Post subject: High Oil Temps |
Optimum oil temps at cruise would be 180-190. Granted, winter time in
the middle part of the country, temps are going to be a bit lower. But
in the summer 210 on climb out is not a concern, at least to the engine
AS LONG AS level off or nose down a little, the oil temp drops back down
into the 165-200 range as Deems mentioned. We are a bit more
conservative, well anal, about max oil temps not exceeding 225 on climb
out on our engines.
One of our customers has his SW cooler (sorry, can't remember the P/N)in
his RV-8 tilted to 23 degrees, which for installation is maximum he can.
His reason is that it allows the air to hit the cooler passages at a
greater angle, making it more cool efficient.
Being as I haven't built mine yet(getting closer Deems) this is food for
thought, I have no direct data on cooler placement or angle of the
mounted cooler. We were just discussing this last year at the RV
cookout, when the subject came up.
Allen Barrett
BPE, Inc.
Jack.Phillips(at)cardinal Guest
Posted: Mon Apr 30, 2007 11:40 am Post subject: High Oil Temps |
Adding some speculation to this thread...
In my RV-4, I can tell to a remarkable degree of accuracy how much oil I
have by watching the oil temp on a hot day. If the oil sump gets just a
little below 6 qts, the oil temp really starts to climb. I normally
keep my oil at 6 quarts (capacity of the O-320 is 8 quarts), but in the
hottest months I try to keep it at 7 quarts just to keep the temps down.
If I put 8 quarts in, I will quickly lose a quart through the breather.
I'm wondering whether it would be useful to have an air-oil separator
and keep the oil at max capacity for better cooling. I have such a
separator on my Pietenpol and since I don't lose any oil through the
breather, the oil consumption on that engine (Continental A65) is
running at about a quart every 25 hours. I'm considering putting an
air-oil separator on the RV-10, but had not considered that it might
help with oil temperature. Helps keep the belly clean, too.
Does anyone have any experience with an RV-10 with an air-oil separator,
and does it still have problems with oil temps?
Jack Phillips
#40610
Tailcone
Posted: Mon Apr 30, 2007 11:53 am Post subject: High Oil Temps |
Mark, do you have any pictures of the louvers you can send me?
If any of you can think about the name of the more efficient oil cooler I would be interested. It was not that warm out on Saturday and I wasn't too concerned with 220, it was just much different than I have previously seen.
I can only imagine what would happen here in Utah when temps get to 90+. I will have add a water injection unit for the oil cooler like the Reno racers have.
I would like to have a system where I rarely see above 200F.
Scott Schmidt
Tim Olson
Posted: Mon Apr 30, 2007 12:09 pm Post subject: High Oil Temps |
Scott, here's a page I wrote up about some cooling improvements with
pics of the louvres:
http://www.myrv10.com/N104CD/maintenance/20061022/index.html
This page in the tips area also has links to the louvres and
where to get them. I have not added them yet.
http://www.myrv10.com/tips/engine_IO540.html
[quote] Mark, do you have any pictures of the louvers you can send me?
previously seen.
Reno racers have.
Scott Schmidt
Posted: Mon Apr 30, 2007 12:19 pm Post subject: High Oil Temps |
Jack, I typically run my oil around 10 quarts. When I landed I checked it and it was around 9.5. I added two quarts to add more thermal mass before taking off.
Tim, I will download the data and take a closer look at it. I sure would like to be able to climb out at 24 square without having oil temp issues. In the winter I have had to adjust power because of CHT. When they get to 400 I start pulling power or decreasing climb rate. But it appears the summer brings other issues. When I was climbing out on Saturday the oil temps were at 220, my CHT was 394.
I have heard the ducting that feeds the oil cooler is 75% the area of the cooler, but with a baffles it would seem there would be enough pressure to push as much air as possible through the cooler. I was wondering if a slightly higher angle of attack (caused by 4 people) increases the pressure on the bottom of the aircraft just slightly which reduces the amount of air flowing out of the cowling. ???????????
Scott Schmidt
bhughes(at)qnsi.net Guest
Posted: Mon Apr 30, 2007 12:24 pm Post subject: High Oil Temps |
Is there any possibility of even the smallest air leak on the pressurized side of the oil cooler? If so some of the air will take the path of least resistance and not pass through the oil cooler core. This lowers the pressure differential between the cooler input and discharge. The box between the firewall and oil cooler face needs to be air tight.
Bobby
40116
(reading too much about liquid cooled engines over the last 3 years)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Monday, April 30, 2007 1:53 PM
Subject: Re: High Oil Temps
Scott Schmidt
----- Original Message ----
Sent: Monday, April 30, 2007 11:57:46 AM
Subject: RE: High Oil Temps
--> RV10-List message posted by: "Mark Ritter" <mritter509(at)msn.com>
Scott,
the oil temp.
Mark (N410MR)
[quote]From: Scott Schmidt <scottmschmidt(at)yahoo.com>
home.
around 170 to 180.
2400?
Tim Olson
Posted: Mon Apr 30, 2007 12:44 pm Post subject: High Oil Temps |
This changes the story a bit....if you're also seeing high
CHT's on climbout in the winter, then I believe you definitely
have to look at your baffling and there is probably a bit of
improvement that can be done. The temps weren't that hot
that day, and my guess is you'll easily be able to drop
a bunch of temperature by some baffling improvements.
Check those links I sent in one of the last emails on the
list. Especially verify that you have prevented air from
flowing under your upper cowl air ramps, and that you have
sealed your air chamber above the engine well. For CHT's,
also file out the slag between the cylinder fins on the
top of your cylinder below the sparkplugs. If you're seeing
heat in more than just one form....CHT's and Oil temps, especially
the fact that you've seen it in the winter, then there is a
problem somewhere. This weekend it hit 85 degrees by me,
but yet I never hit 400 CHT on climbout except for under the
most extreme of hot days.
Personally, I had thought I did a good job on my baffles and
cowl sealing. It wasn't until I really dug in that I realized
that my original job sucked in comparison to what was possible.
I really doubt that just the additional people load changed
your AOA enough to make a huge difference. I fly a large
percentage of my time with 3-4 seats filled, and even when
it's the kids there, that means I carry lots of baggage too.
The airspeed you climb at will affect the temps a lot more, I
would bet. I climb like you (106kts approx.).
I would seriously dig into the cowling/baffling/cooling.
Check that page I put together. I think there's enough there
to figure it all out. That tips page too has the file type
I used.
[quote] Jack, I typically run my oil around 10 quarts. When I landed I checked
before taking off.
Scott Schmidt
Posted: Mon Apr 30, 2007 12:51 pm Post subject: High Oil Temps |
Scott,
I bought mine from Alex DeDominicis (972) 775-1896. He has pictures on his
web site. There are four RV's at 50R (Central Texas) that have the louvers
installed including Keith Uhls RV-7 who I think you have met. We all swear
by them. Folks that have installed them are seeing their oil temp going
down by 20-25 degrees (down to 185 degree range in my RV-10) allowing for
faster climbs without having to level off to cool things down (except on
really really hot days).
Getting oil temp too cold is not a problem for me. If it gets that cold I
start whinning about where is Gore's global warming, grab an electric
blanket and get in the fetal position and don't go outside until it warms up
to at least 60.
I'll take some pictures tomorrow if I get to the a/p. Once on, you can't
see them except when cleaning the dirty side of the airplane.
Hope all is well.
Mark
N410MR
Date: Mon, 30 Apr 2007 12:53:01 -0700 (PDT)
racers have.
Scott Schmidt
Posted: Mon Apr 30, 2007 2:02 pm Post subject: High Oil Temps |
Have you tried climing at 115Kts indicated. That seems to be the most
efficient speed for climging from our testing. On the Sorcerer putting
either 110Kts or 115Kts is standard for us on climb. It should run a little
cooler that way.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Randy(at)abros.com Guest
Posted: Mon Apr 30, 2007 3:57 pm Post subject: High Oil Temps |
Well I need to chime in here. On one trip about 4 months after my first
flight Cheryl and I had to make a trip to Redmond Or and pick up two
passengers. We were coming back to the valley. I landed at Redmond with
the air temp about 95 deg. The airport is 3200ft or so field elevation.
We filled up with fuel loaded about 75 lbs of baggage and 4 passengers.
I mean we were at gross. We headed for the runway. At the end of the
runway it was 101 deg. We left the ground at about the 1500 ft. mark.
Now the engine was heat soaked and we were only on the ground for 20 min
(no cool off time at all). On climb out Rob's engine monitor squawked
check oil temp. We were at 235 and climbing. At 500 ft AGL I lowered
the nose so we were climbing at 100ft per minute. The engine temp hit
239 then leveled off before dropping to about 225. I called the engine
rebuilder and he said that it would be ok and the correct solution was
lower the nose and make sure it started to drop. He also has told me
that in order to get the moisture out of an engine in the winter time to
get the oil temp to 180 deg. Below that the moisture that builds sitting
in the hanger for a month or so will not be evaporated. My normal temps
are 185 to 205 most of the time. Good flying. Randy 40006
Kellym
Posted: Mon Apr 30, 2007 7:03 pm Post subject: High Oil Temps |
I used to think my Mooney ran 220 based on factory crappy gage. Put in
UBG16 and found I run 195-200 most of the time and can keep it under 210
without much trouble. I consider 210 where I need to take action to
reduce temps.
KM
KCHD
Deems Davis wrote:
live in Phoenix, and high temperatures is a fact of life. talking w/
fellows (at) EAA chpt mtgs. reveals that the RV6,7,8" guys all buy the
biggest and most efficient oil cooler they can. I was told of one that
was 20% more efficient than the one that Van's ships, I don't recall
it's name/number but could find out if you need the info. Some have
had success mounting the oil cooler directly behind the #4 cyl on the
baffling as opposed to the firewall. I doubt there's room enough on
Deems Davis # 406
> Need some advise. *
KCHD |
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Mon Apr 30, 2007 9:10 pm Post subject: High Oil Temps |
Might be worth check the oil temp sender for accuracy first.
Kevin
40494
tail/empennage
do not archive.
_________________ Kevin
40494
do not archive |
Posted: Tue May 01, 2007 8:17 am Post subject: High Oil Temps |
I had quite a long conversation with a gentlemen from Airflow Systems yesterday (I feel bad because I can't remember his name now). They have developed a new oil cooler that is apparently more efficient than the one Van's supplies. It is the same dimensions and should bolt directly to the mount supplied by Van's. From their findings they have seen a decrease in oil temp of 8-15 degrees.
He is also doing work with an RV-10 out there putting thermal couples all around the engine and measuring the efficiency of the cooling. He has come to many of the same conclusions you all have. 1. - Tunnel heat is caused by the exhaust and not the heating system, and 2. - There needs to be more outlets on the bottom or side of the cowling. He feels the best location for more louvers would be on the side of the cowl but the bottom would work as well. He also feels there is a turbulent area behind the cowl on the bottom on the plane that is causing some cooling inefficiencies and drag. (Van would be rolling his eyes if he heard that one. hahaha. He would say yup, who cares)
Like I mentioned yesterday, I also feel the cooling is decreases due to the increase of angle of attack caused by 4 people in the aircraft. If I climb at 105 knots with 2 and 4 people with the exact same power settings but the oil temp is higher with 4 people there has to be an effect on cooling. This makes perfect sense. With a higher angle of attack (I will have to record AOA with 2 and 4 people) there is a slightly higher pressure on the bottom of the aircraft which will reduce the airflow through the cowl. He agreed this occurs on all of Van's aircraft. The more weight you have in the aircraft, the faster IAS you have to fly while climbing to maintain the same oil temps.
I agree with Tim's statement as well concerning being too cool in the winter. My temps in the winter are very close to the 165 range so increasing cooling too much will be bad during those cold months. Seems like the best scenario is to add louvers to the bottom, possibly add the more efficient oil cooler and in the winter I will have to add the oil cooler shutter from Vans. http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1178035620-106-414&browse=engines&product=oil_shutter
The more I talk with people though, the more I am finding lots of people are dealing this issue. Alex in Texas has 2 oil coolers on his RV-10 and is now switching to the new oil cooler from Airflow Systems.
Scott Schmidt
