		drfred(at)suddenlinkmail. Guest
				 Posted: Thu May 03, 2007 12:50 pm    Post subject: Tunnel access cover |
				Scott;
 What kind of service will the filter need?  Will it be something that
 should be replaced on an annual basis?  Or is this solution just for
 visualization of the tunnel and filter?
 Fred Williams
		scottmschmidt(at)yahoo.co Guest
				 Posted: Thu May 03, 2007 1:33 pm    Post subject: Tunnel access cover |
				I cannot find my instructions but I understand the manufacture recommends to check after the first 10-20 hours, then at every annual.
  You can replace it but it is made to be cleaned. When I checked mine I for sure thought I would find at least a small piece of pro-seal but nothing but a little piece of lint.
  The whole purpose of the tunnel access was to remove the fuel filter, unscrew it and check it.  It does also make it easy to inspect the whole fuel system for leaks.
  Here is a link to Dan Checkoway's 2005 annual. He has a picture of it here.
  http://www.rvproject.com/annual2005.html
 Scott Schmidt
 scottmschmidt(at)yahoo.com
