John H Murphy
Joined: 03 Jan 2007 Posts: 78 Location: Henderson, NV
Posted: Tue May 01, 2007 8:37 pm Post subject: Firestar II - installation of electric start |
Has anyone with a Firestar II installed an electric start on their aircraft? There does not appear to be enough room for the electric start. I'm trying to keep my Ballistic shute *BRS* model 750 & the starter. It also appears the engine case needs to be modifed to allow all the parts to fit. There was no instructions with my starter so I'm trying to figure it out as I go along.
Blumax008(at)aol.com Guest
Posted: Wed May 02, 2007 8:45 am Post subject: Firestar II - installation of electric start |
You could put an E drive on it which has the starter installed with (beside) the gearbox.
See what's free at AOL.com.
John H Murphy
Posted: Wed May 02, 2007 1:11 pm Post subject: Re: Firestar II - installation of electric start |
I've had several folks tell me the GPL starter is the way to go. It has the starter sitting sideways instead of straight back like my Rotax starter.
planecrazzzy Guest
Posted: Wed May 02, 2007 5:26 pm Post subject: Re: Firestar II - installation of electric start |
I have the GPL starter....Works great...I like it....But it adds about
30 -35 lbs to yer plane ...Starter / housing/wiring/Battery/ignition switch
In the attached picture....you can see the starter & Housing
Gotta Fly...
Mike & "Jaz" in MN
60.89 KB |
440 Time(s) |
