wjones(at)brazoriainet.co Guest
Posted: Tue May 01, 2007 3:47 am Post subject: Micro limit switches |
Hello group ,can anyone on the list direct me to a source where I can buy a limit switch for my flap motor on my 601XL . Thanks
Wade Jones South Texas
601XL plans building
Cont. 0200
Posted: Tue May 01, 2007 5:05 am Post subject: Micro limit switches |
Hi Wade,
Digikey is a great online seller of all sorts of electronic stuff including just about every switch known to man. You can get there with: http://www.digikey.com/
The bad news is that limit switches usually are designed as part of an integrated electromechanical package including the motor, switches, and lead screw or other means of moving your stuff. You might find designing your own limit switch system a bit overwhelming.
Good luck,
Paul
XL fuselage
At 04:44 AM 5/1/2007, you wrote:
[quote]Hello group ,can anyone on the list direct me to a source where I can buy a limit switch for my flap motor on my 601XL . Thanks
Cont. 0200
Posted: Tue May 01, 2007 6:10 am Post subject: Micro limit switches |
Thanks a lot ,Paul & Zed .That site is just what I needed .
Cont. 0200
TxDave
Posted: Tue May 01, 2007 9:16 am Post subject: Re: Micro limit switches |
Hey Wade,
Try these folks.
http://www.mouser.com/microswitch/
Dave Clay
Posted: Tue May 01, 2007 11:05 am Post subject: Micro limit switches |
Thanks Dave ,always good to have another source .I still need some more
response to my earlier question about the nose gear tube .Could someone look
at the factory gear and tell me if the 3/4" tubes go all the way thru or
are they only stubbed on .I feel sure almost sure that they go thru the 2" .
Thanks do not archive
Cont. 0200
Posted: Tue May 01, 2007 11:25 am Post subject: Micro limit switches |
| Quote: | > Could someone look at the factory gear and tell me if the 3/4" tubes go
all the way thru or are they only stubbed on.
Yes, both the tube that the bungee hooks to and the tube that the steering
rods connect to pass all the way through. I just slid a wire through both.
-- Craig
Posted: Tue May 01, 2007 2:01 pm Post subject: Micro limit switches |
Thanks Craig ,thats what I needed to know .
Cont. 0200
Posted: Tue May 01, 2007 4:05 pm Post subject: Micro limit switches |
Wade,
The steering tube goes all the way thru the strut tube and the weld
recovers the strength
of both. A stubbed tube would likely not do the job for long.
wade jones wrote:
more response to my earlier question about the nose gear tube .Could
someone look at the factory gear and tell me if the 3/4" tubes go all
the way thru or are they only stubbed on .I feel sure almost sure that
they go thru the 2" . Thanks do not archive
Posted: Tue May 01, 2007 6:08 pm Post subject: Micro limit switches |
Thanks Larry ,thats the way I thought it sould be .
Cont. 0200
