by0ung(at)brigham.net Guest
Posted: Tue May 01, 2007 6:22 am Post subject: W&B |
Been working off line with Robert Laird on his W&B and come up with a
small spread sheet that will calculate the exact arm for the pilot, fuel, or
any other item added to a plane.... no more guessing at the location of
the belly button or calculating the center of mass of the fuel tanks
etc...
The spread sheet is not been made to look real purdy,,,,, but it works.
I put in some example numbers to test functionally .... you can erase the
test numbers and save it or duplicate it in a format that is better thought
out.
Boyd
W&B_kolb-pilot-arm.xls |
8.5 KB |
345 Time(s) |
rlaird
Posted: Tue May 01, 2007 6:56 am Post subject: W&B |
Ok, now that I've got the w&b done, who's got a MkIIIC POH that I can borrow (in Word format, if possible).
Thanks!
-- Robert
On 5/1/07, boyd <by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote:[quote]Been working off line with Robert Laird on his W&B and come up with a
etc...
out.
Boyd
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Tue May 01, 2007 7:38 am Post subject: W&B |
Robert,
I asked for a POH several years ago and the consensus at that time was that no one had one. Hopefully that has changed, If one showes up please post it to the group...
Mike
Robert Laird <rlaird(at)cavediver.com> wrote:
[quote]Ok, now that I've got the w&b done, who's got a MkIIIC POH that I can borrow (in Word format, if possible).
Thanks!
-- Robert
On 5/1/07, boyd <by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote: [quote]Been working off line with Robert Laird on his W&B and come up with a
small spread sheet [quote][b]
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
rlaird
Posted: Tue May 01, 2007 8:11 am Post subject: W&B |
Ok, I will.
And if one doesn't show up, I'll take the POH I wrote a few years ago for an Aventura II and re-write it for the Kolb, and post it. I'm at a bit of a disadvantage, though, since I don't have -any- Kolb documentation, plans, schematics, etc.
-- Robert
On 5/1/07, Michael Sharp <kolbdriver(at)mlsharp.com (kolbdriver(at)mlsharp.com)> wrote:[quote] Robert,
Mike
Thanks!
-- Robert
On 5/1/07, boyd < by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote: [quote]Been working off line with Robert Laird on his W&B and come up with a
small spread sheet [quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com [quote][b]
Robert Laird
Houston, TX area
