swrpilot(at)bellsouth.net Guest
Posted: Mon Apr 30, 2007 11:10 am Post subject: Traffic at FL60... |
Off topic again but this is just too cool...
Global Hawk
[img]cid:001c01c78b5b$09e536d0$6902a8c0(at)SWRMediaCenter[/img]
A pic of the Global Hawk UAV that returned from Iraq on Monday under its own power. (Iraq to Edwards AFB in CA) - Not transported via C5 or C17. Notice the mission paintings on the fuselage. It's actually over 250 missions. That's a long way for a remotely-piloted aircraft. Think of the technology (and the required quality of the data link to fly it remotely). Not only that but the pilot controlled it from a nice warm control panel at Edwards AFB. It has really long legs - - -it can stay up for almost 2 days at altitudes above 60k.
79.1 KB |
223 Time(s) |
Posted: Mon Apr 30, 2007 12:04 pm Post subject: Traffic at FL60... |
"That's a long way for a remotely-piloted aircraft. Think of the
technology (and the
required quality of the data link to fly it remotely). "
I know a retired 747 captain that said eventually the pilot inside a
commercial airliner would be housed inside a glass tube with a little
sticker on the outside which reads "Break glass in the event of an
emergency"
| Quote: | From: "Steven Roberts" <swrpilot(at)bellsouth.net>
Subject: Traffic at FL60...
Date: Mon, 30 Apr 2007 15:09:12 -0400
Global Hawk
<< image001.jpg >>
LarryRosen
Posted: Mon Apr 30, 2007 4:41 pm Post subject: Traffic at FL60... |
| Quote: | | Quote: | | Tim Dawson-Townsend of Avidyne fame is now at Aurora Flight Sciences. So you check out there website | | <http://www.aurora.aero/aerostructures/GlobalHawk.html>
and you see this:
[img]cid:part1.00080905.08030708(at)comcast.net[/img]
Only 35 to 36 hours of Endurance with a range of 12,000 nm.
Cool stuff.
[img]cid:part2.04030306.07090706(at)comcast.net[/img]
Larry Rosen
21.39 KB |
236 Time(s) |
19.18 KB |
233 Time(s) |
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Mon Apr 30, 2007 6:18 pm Post subject: Traffic at FL60... |
And also thank the mission guys (and Gals) at Nellis that work wierd, long, hours. I'm truly amazed at what they do. Heck, I had enough trouble with an R/C airplane I could see, much less control one on the other side of the globe. Kudos, Guys & Gals, and you know who you are!!!
Linn
Steven Roberts wrote:
[quote] v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { BEHAVIOR: url(#default#VML) } <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Global Hawk
(Pic deleted for bandwidth)
Posted: Mon Apr 30, 2007 6:29 pm Post subject: Traffic at FL60... |
Sorry, The nellis folks fly the predator, not the hawk ...... but then my info is rather dated! Either way ...... great job!!!
Linn
linn Walters wrote:
[quote] And also thank the mission guys (and Gals) at Nellis that work wierd, long, hours. I'm truly amazed at what they do. Heck, I had enough trouble with an R/C airplane I could see, much less control one on the other side of the globe. Kudos, Guys & Gals, and you know who you are!!!
Linn
| Quote: | v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { BEHAVIOR: url(#default#VML) } <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Global Hawk
| [b]
