matronics(at)cencula.com Guest
Posted: Sat Apr 28, 2007 9:40 am Post subject: Main spar flange bend angle problem |
RV-ers,
I'm trying to figure out what to do about a problem with my main spar flanges.
The problem is detailed at:
http://www.our7a.com/20070426.html
http://www.our7a.com/20070428.html
Essentially, I think I need to tweak the bend angle of the main spar flanges
in some locations.
The problem is that the material is THICK and I've already riveted on my main
ribs, so how can I tweak this angle?
I suppose I could remove all the main ribs. It wouldn't be terrible since
they're only attached to the main spar at this point, but I'd prefer to avoid
that hassle if possible.
Any thoughts on how to tweak that spar flange? Seaming pliers seems like a
rough way to go.
Also, does anyone know what this angle is supposed to actually be?
Mike Cencula
wskimike(at)mchsi.com Guest
Posted: Sat Apr 28, 2007 4:07 pm Post subject: Main spar flange bend angle problem |
Use a shim rather than trying to bend the rib because you may crack it. It
would be better to shim it and don't
even think about bending the wing spar.
Mike
Posted: Sat Apr 28, 2007 5:00 pm Post subject: Main spar flange bend angle problem |
Michael D. Cencula wrote:
RV-ers,
in some locations.
rough way to go.
Mike Cencula
Hi Mike,
If the flanges really are bent too much or not enough, you might be able
to pull the flange down with a bar-clamp (like you'd use in cabinet
making) and some big stiff angle to spread the load along the spar flange.
Having said that:
What does it look like if you cleco on the nose rib & wrap a strip of AL
over the rib & spar flange? If that lines up and looks ok, read on.
IIRC, my spar flanges weren't exactly square to the web (but I think
they were consistent in their bends).
The problem I *did* have, that caused some of the main rib/main spar
joints to look just like yours, was a few bad ribs. After fighting the
same gap between the spar flange & rib flange I see in yours, I noticed
that that the other pair of flanges (top vs. bottom on the same rib) was
too tight. Closer inspection revealed that the tooling holes in the
problem ribs were distorted as if they had been dimpled off-center. The
rib blanks had shifted in the punch press, causing all the holes to be
punched offset by a fraction of an inch. The ribs' web flange holes
being offset caused the rib to sit too high (or low, don't remember
which) in relation to the spar. Further evidence was that the prepunched
holes on the rib's top flange were a different distance from the edge
from the holes on the bottom flange. All these holes get punched before
the rib's flanges are bent.
A call to Van's tech help got the standard 'it's your fault; you're
doing something wrong', followed by asking for proof (I supplied it),
followed by the ubiquitous 'we've never seen this before', followed by
'we'll send you new parts & if the old one really is defective when you
return it, we won't charge you for the new one'. They didn't charge me
for the new one.
I don't know if it's relevant to your problem, but it really does look
like what I saw with mine.
Charlie
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Sat Apr 28, 2007 5:53 pm Post subject: Main spar flange bend angle problem |
I vaguely remember a similar problem here, but I used the O ring (s) trick
around the rivet so that the bucking bar was basically pushing the little
flange of the rib against the flange of the main spar. I'd be VERY reluctant
to try to bend the main spar material in any way.
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
Posted: Tue May 01, 2007 8:42 pm Post subject: Main spar flange bend angle problem |
For the archive:
After a talking with Scott at Van's, I learned that the spar flange angles
are:
Top flange 88.5 +/-.5 degrees
Bottom flange 89 +/-.5 degrees
Measured between flange and web (in the corner where the main ribs sit)
My spar flanges were definitely out of spec. Scott indicated that they have
had several spars with this problem. Apparently the spar channel is OK until
it is assembled with the top and bottom bars. This causes the flanges to
open up a bit.
Scott recommended the same fix they use at Van's when they encounter this
problem...cut a slot in a 2x4 and use that as a lever to tweak the flanges
into positon. My situation was a bit more difficult because I already had
all the platenuts attached, so I needed a rather narrow tool to fit between
the platenuts. I tried several pieces of wood and composite material all of
which broke on the first try. I ended up getting a piece of 1/2 inch thick
aluminum bar from the scrap tub at work and cut a slot in it.
After removing the main ribs (that was a chore) and reworking the left spar
flanges, I'd qualify results as very good. Not perfect, but it's 95% better
than it was originally. Rib #5 was the worst rib with about .090 gap. After
reworking the flanges, there is essentially no gap between the spar flange
and the rib joggle flange. A similar improvement resulted at all the other
ribs as well.
Hopefully someone will find this information useful in the future.
Happy building,
Mike
On Saturday April 28 2007 01:39 pm, Michael D. Cencula wrote:
RV-ers,
flanges. The problem is detailed at:
flanges in some locations.
main ribs, so how can I tweak this angle?
avoid that hassle if possible.
rough way to go.
Mike Cencula
