rparigor(at)suffolk.lib.n Guest
Posted: Sun Apr 29, 2007 4:22 pm Post subject: Into wind or downwind to run cooler on ground? |
I just read an artilce in April Kitplanes "Baffled by Baffles". One of the
things discovered after tufting everything including the intake for large
displacement aircooled engine was when pointed into the wind, even doing
run up there was absolute no airflow! They descided to not go flying till
they figured out why, and when headed back the second they turned
downwind, air began to flow (They had small camera able to view what was
going on). They began to fool on ground and sure as anything, no flow into
wind, flow begins when downwind. Conclusion was the prop was at more of an
angle of attack pointed downwind and was creating a larger low pressure
area.
Has anyone actual tried pointing downwind, versus pointing into the wind
when stuck on the ground for extended periods with a Europa? Does pointing
downwind yield lower temperatures?
Especial interested in results with monowheel with "Groundloop" adjustable
Airmaster prop (course and fine tested)?
Thx.
Ron Parigoris
DuncanPilot
Posted: Mon Apr 30, 2007 2:59 am Post subject: Into wind or downwind to run cooler on ground? |
We have. Into wind was better for our Europa with a 3-blade Warp prop. The
reason I mention the prop is that we switched prop and saw considerable
improvement in the cooling.
My theory is that our 3 blade Warp prop was not good at pushing air into the
cowling so pointing it into wind made a big difference. I am not sure how
this theory fits into your scenario?????
Duncan Bennett
_________________ Duncan
G-BYFG. Europa XS. Jabiru 3300 |
willie.harrison(at)tinyon Guest
Posted: Mon Apr 30, 2007 3:30 am Post subject: Into wind or downwind to run cooler on ground? |
My experience with WD is identical to Duncan's. Last year I had a
boil-over (admittedly with the pre-mod coolant pressure cap) whilst
held by ATC for 10 minutes pointing downwind on a taxiway. No
problems now that I make a point of swinging into wind whilst holding.
Willie Harrison
On 30 Apr 2007, at 11:57, Duncan Bennett wrote:
<Duncan.Bennett(at)talktalk.net>
prop. The
considerable
into the
sure how
Duncan Bennett
Posted: Mon Apr 30, 2007 4:30 am Post subject: Into wind or downwind to run cooler on ground? |
Some guys here in UK with a Jab 6 tri gear had bad cooling problems with
a Warp Drive 3 blade. Changed to a 2 blade with wider roots close to the
hub and that improved the cooling significantly
Graham
Duncan Bennett
ami(at)mcfadyean.freeserv Guest
Posted: Mon Apr 30, 2007 12:03 pm Post subject: Into wind or downwind to run cooler on ground? |
Warms up quicker (therefore less cooling airflow) when pointed downwind on
the ground. Also, prop vibration worse.
Sorry to confuse the 'theory'!
Duncan McF.
