Engine Lord Mounts
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
Speedy11(at)aol.com
PostPosted: Sun Apr 29, 2007 3:04 pm    Post subject: Engine Lord Mounts Reply with quote
I bought the Van's Lord mount kit for my IO-390 (same dimensions as IO-360).
For anyone who's installed their engine, to what value did you torque the 7/16 engine mounting bolts?
Did you use 475 inch pounds? Did you use coarse thread torque or fine thread?
Stan Sutterfield
See what's free at AOL.com.
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
grant.piper(at)bigpond.co
PostPosted: Sun Apr 29, 2007 3:18 pm    Post subject: Engine Lord Mounts Reply with quote
Hi Stan,
You will have trouble getting a torque wrench onto these bolts, and it may be of limited use. The rubber mounts must be compressed such that the bolt is tight on the inner spacer (this limits the amount of compression). The compression of the rubber will add to your torque reading also. I've only installed a couple of enginmes, but in each case did the bolts up tight on the spacer then as required to get the cotter pins in.
regards,
Grant
Float Flyr
PostPosted: Mon Apr 30, 2007 3:11 pm    Post subject: Engine Lord Mounts Reply with quote
There is a procedure that requires always torquing a nut...not a bolt. Unless the manufacturer of the plane specifies the bolt be torqued. There certainly are places where bolts need to be torqued into fittings. My Ivo prop is an example of that.
That being said; you are in fact the manufacturer of the plane.
On engine mounts I would do exactly as you said; torque (the nut) until the slack was taken out of the mount and a cotter pin could be set. Often I have used crows feet for doing this, making torque adjustments for the offset of the crows foot.
[img]cid:658395822(at)30042007-224D[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
 Filesize:  19.77 KB
 Viewed:  849 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Speedy11(at)aol.com
PostPosted: Mon Apr 30, 2007 4:46 pm    Post subject: Engine Lord Mounts Reply with quote
Grant,
Thanks for your reply,
I'm torquing the engine bolts by torquing the bolt head - since I can't get to the nut. It's the only way I can figure to torque them. The rubbers are compressed and the spacers seated. I just want to make sure I'm torquing the correct amount.
Mahlon, any comment on this?
Stan
[quote]Hi Stan,
cotter pins in.
regards,
Grant
Jim Baker
PostPosted: Mon Apr 30, 2007 5:20 pm    Post subject: Engine Lord Mounts Reply with quote
Ah, the luxury of cotter pins....but not on my io520. 40-42 lb ft
and no retention other than torque.......
I think mine were 1/2, works out to 550-600 lb in. 7/16 would be
400-450 lb in. The internal spacers will limit compression. No oil
on threads for torque....
thread?
Jim Baker
580.788.2779
Elmore City, OK
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
