Posted: Wed May 02, 2007 8:08 am Post subject: section 43, transparencies. |
A joggle is where a molded part indents in to receive another part so that
parts make a lap joint. In this email I am speaking of the window joggles on
the cabin top.
I finished the sizing of the rear windows and I noticed that both the right
and left window joggles on the cabin top for the rear windows, at the
forward edge, mid way up, are both too shallow to allow the plexiglass to
fit flush to the outer skin of the cabin top. It is about 1/8" too shallow.
If too deep, shims are used to build it up.
The question is, are people finding this area of the cabin top needs to be
built up once the doors are installed, because the door stands proud or
should I sand some material out of the joggle(It is solid fiberglass) so
that the plexiglass sits flush?
Why is this fiberglass part so poorly produced? It is as though the window
cutouts(Joggles) were scribed by a kindergardener. Keeping the window edge
trimming distance consistent is very difficult when nothing makes consistent
arcs or staight lines. This part is pretty shameful.
JOhn
Deems Davis
Posted: Wed May 02, 2007 8:59 am Post subject: section 43, transparencies. |
John, Having recently completed this step. Here's my experience.
Rear windows: The joggle was inconsistent in its depth and depending
upon how much of a gap you left when trimming the windows the
inconsistencies in the corner of the joggle contributed to the windows
fitting unevenly. (window stands proud if trimmed very closely) I used
the side of a small heavy duty cutoff wheel in a Dremel tool and 60
grit sandpaper to 'clean-out' the corners of the joggle and to relieve
the joggle seat where necessary to make it flat and as consistent a seat
as possible. Once that was done I found that it was necessary to shim
the rear windows with washers to get them flush with the cabin cover.
Door windows, The same issue with the inconsistent depth of the joggle
joints as for the rear windows, and I applied the same corrective
action. However I found that the door windows did NOT require shimming,
and in fact despite the corrective action, I found that a couple of the
corners were a bit 'proud' and required some sanding to fair/blend into
the door skins.
Re fitting the Cabin cover to the doors. I did some extensive work to
ensure that the doors and cabin cover matched
http://deemsrv10.com/cabinwindowslogindex.html. I was not happy with the
rounded edge of the cabin cover and the relatively straight edge of the
doors. So when fitting the doors. I built up the cabin cover door
opening so that I could match the appearance of the door. It is an
entirely cosmetic activity, but I found that there were minor
inconsistencies in the exterior of the door skins and the cabin cover
that could only be corrected when the doors are fit. It you've haven't
already fit your doors, you might hold off on attaching the windows
until you have, as that will effect the 'fairing' if you choose to do so.
The disconnect between the quality on the alum parts vs the fiberglass
parts in the kit is appalling, the only thing more appalling is Van's
unwillingness to do anything about it.
Deems Davis # 406
Finishing - ( A Misnomer ! )
John Gonzalez wrote:
that parts make a lap joint. In this email I am speaking of the window
joggles on the cabin top.
right and left window joggles on the cabin top for the rear windows,
at the forward edge, mid way up, are both too shallow to allow the
plexiglass to fit flush to the outer skin of the cabin top. It is
about 1/8" too shallow. If too deep, shims are used to build it up.
to be built up once the doors are installed, because the door stands
proud or should I sand some material out of the joggle(It is solid
fiberglass) so that the plexiglass sits flush?
window cutouts(Joggles) were scribed by a kindergardener. Keeping the
window edge trimming distance consistent is very difficult when
nothing makes consistent arcs or staight lines. This part is pretty
shameful.
JOhn
jeff(at)westcottpress.com Guest
Posted: Wed May 02, 2007 9:28 am Post subject: section 43, transparencies. |
Hi John,
Having just returned from the AirCrafters composite class (where we
fit a cabin top), I believe I can actually answer this one. You do
wind up building up the cabin top (with flox) to bring it up flush
with the window. You'll find that you also need to do it on the
forward side of the door.
Jeff Carpenter
40304
HIDs
On May 2, 2007, at 9:06 AM, John Gonzalez wrote:
<indigoonlatigo(at)msn.com>
so that parts make a lap joint. In this email I am speaking of the
window joggles on the cabin top.
the right and left window joggles on the cabin top for the rear
windows, at the forward edge, mid way up, are both too shallow to
allow the plexiglass to fit flush to the outer skin of the cabin
top. It is about 1/8" too shallow. If too deep, shims are used to
build it up.
needs to be built up once the doors are installed, because the door
stands proud or should I sand some material out of the joggle(It is
solid fiberglass) so that the plexiglass sits flush?
the window edge trimming distance consistent is very difficult when
shameful.
JOhn
Posted: Wed May 02, 2007 10:01 am Post subject: section 43, transparencies. |
I don't know a LOT about fiberglass work, but from people I have talked to,
the fiberglass parts on the -10, for the most part, are fairly decent
quality. I am sure I will get slammed for saying that, but I am just
quoting what I have heard Lancair builders say, mainly about the cabin top
and cowling. It is certainly a TON easier to get an exact aluminum part
than an exact fiberglass part (science vs. art? - please don't slam me for
this, just IMHO). The nice thing about fiberglass is that you can just
build up or sand down to get something to fit.
OK, now to a response. I have seen the same issue you are talking about,
with the rear door frame on the cabin top having kind of a "flat" in it
where either the mold was wrong or the layup was wrong, but we just build
that area up after the window is in place and the door is installed. A good
way to get a good fit is to get the windows and doors installed, then put
some kind of tape on the part that is out further, then fill in that area
with Flox or Micro (depending on how far it needs to be built up), then sand
down to your tape and it should match nicely. We have even gone as far in
the past as filling both parts, sanding smooth, then running a cutting wheel
down between the two to get a nice even crack. It is hard to get the doors
perfect (or possibly impossible, especially with such a lightweight and weak
door), but you can get it pretty good. I would also agree with Deems that
you want to fit the door on the fuse and then put the window on the door
while it is on the fuse to make sure to hold the right shape.
I hope that seems somewhat coherent.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Posted: Wed May 02, 2007 10:36 am Post subject: section 43, transparencies. |
Hi guys,
Thanks for the replies.
I actually enjoy this fiberglass stuff, but I don't appreciate having to do
a lot of extra work that should have been done correctly to begin with,
epecially when I(we)still have so many other things to do. It typically
would be a lot of work even with a nicely molded part.
JOhn
[quote]From: "Jesse Saint" <jesse(at)saintaviation.com>
Subject: RE: section 43, transparencies.
Date: Wed, 2 May 2007 14:00:53 -0400
good
sand
wheel
weak
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
AV8ORJWC
Posted: Wed May 02, 2007 6:32 pm Post subject: section 43, transparencies. |
Acknowledged with no acceptable answer.
Watch for a solution at OSH '07.
John Cox
