ptiller(at)lolacars.com Guest
Posted: Wed Apr 25, 2007 3:59 am Post subject: Warp Drive propeller blades |
Hi,
I've searched this forum to see if I can find the answer but I can't.
So, can anyone tell me why on the 62" Warp Drive ground adjustable propeller, tapered blades are recommended for a Rotax 912 and broad blades are recommended for a 912S and 914?
What is the issue with running a tapered blade on a 912S or a broad blade on a 912?
Yours,
'Newbie to Propeller design'
Visit - www.EuropaOwners.org
Posted: Wed Apr 25, 2007 5:26 am Post subject: Warp Drive propeller blades |
Phil
it's the power absorption. The tapered blade matches the power output of
the 912, so allows the engine to develop enough rpm for the power needed
for take oiff and climb..
912S & 914 need more blade area to absorb the power. Tapered blades will
over rev too easily. Tapering a broad blade is maybe the cheap way to do
it, they can use the same mould for either then cut to suit. My guess
anyway.
Graham
flyingphil2 wrote:
Hi,
Yours,
Graham Singleton
Tel: +441629820187
Mob: +447739582005
william(at)wrmills.plus.c Guest
Posted: Thu Apr 26, 2007 8:53 pm Post subject: Warp Drive propeller blades |
Your guess is correct, Graham. I visited the Warp Drive stand at S n F last
year and they confirmed they have only one mould for all blades.
William
Posted: Fri Apr 27, 2007 8:38 am Post subject: Warp Drive propeller blades |
It's amazing that these props work at all at the speeds we fly, they
were designed and developed on Microlights.
Graham
William Mills wrote:
<william(at)wrmills.plus.com>
last year and they confirmed they have only one mould for all blades.
William
gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Fri Apr 27, 2007 9:02 am Post subject: Warp Drive propeller blades |
Thats just it Graham, they DON'T work at all speeds we fly, only the lower speeds.
I gained 20 mph on the top end and lost no climb from the WD by going to a custom designed
fixed pitch prop.
Glenn
| Quote: | Date: Fri, 27 Apr 2007 17:39:23 +0100
Subject: Re: Europa-List: Warp Drive propeller blades
--> Europa-List message posted by: Graham Singleton <grahamsingleton(at)btinternet.com>
Graham
> --> Europa-List message posted by: "William Mills"
> Regards,
> W========================>
Get news, entertainment and everything you care about at Live.com. Check it out! [quote][b]
jeff(at)rmmm.net Guest
Posted: Fri Apr 27, 2007 10:23 am Post subject: Warp Drive propeller blades |
I would be interested in knowing info on this prop Glenn,
Jeff
N128LJ / Gold Rush
On Apr 27, 2007, at 12:02 PM, glenn crowder wrote:
| Quote: | Thats just it Graham, they DON'T work at all speeds we fly, only
the lower speeds.
fixed pitch prop.
Glenn
> From: grahamsingleton(at)btinternet.com
> To: europa-list(at)matronics.com
> Subject: Re: Warp Drive propeller blades
> Graham
n F
blades.
> > Regards,
Check it out!
Jeff Roberts
Eagleville Marketing Group / EMG
488 Beasley RD.
Eagleville TN 37060
615-355-7575 Office
615-406-8651 Cell
615-534-1082 Fax
Please note our name & address change.
gcrowder2
Posted: Fri Apr 27, 2007 11:06 am Post subject: Warp Drive propeller blades |
Hey Jeff - I am using a Catto fixed pitch 3 blade, 64 x 62 on my 125 hp EA81 powered
mono. Here is an 8 page Vans Air Force forum thread that is discussing the Catto vs other
fixed pitch AND constant speed units. The general consensus is that the Catto fixed
pitch is just as good on the RV as a Hartzell C/S unit and 20 lbs lighter for thousands less.
I'm sure Craig would build a 912 or 914 optimized prop if a few people got interested.
http://www.vansairforce.com/community/showthread.php?t=12964&page=1&pp=10
There is a new design by Paul Lipps that Catto is also producing, pic below. This
should be the direction of future prop design. An article by Paul Lipps on his prop
design is here:
http://www.batterson.net/EAA499/Issue77_8-13.pdf
This ones pricey for a fixed pitch because of the laminar flow prop airfoil is much
harder to carve at $3200 US. Plan on a long wait - up to a year.
I am ordering a Lipps design prop. I hope to use the exact same profile as Lipps
uses on his 0-235 powered Lancair as hp and prop rpm are the same.
Glenn
| Quote: | From: jeff(at)rmmm.net
Date: Fri, 27 Apr 2007 13:21:20 -0500
.ExternalClass .EC_EmailQuote{margin-left:1pt;padding-left:4pt;border-left:#800000 2px solid;} I would be interested in knowing info on this prop Glenn,
Jeff
N128LJ / Gold Rush
fixed pitch prop.
Glenn
Graham
> --> Europa-List message posted by: 'William Mills'
> Regards,
http://forums.matronics.com
Jeff Roberts
488 Beasley RD.
Eagleville TN 37060
615-355-7575 Office
615-406-8651 Cell
615-534-1082 Fax
Please note our name & addrsp; - The Europa-List EmailEuropa-List" target=_blank>http://www.matronics.com/Navigator?Europa-List - NEW MATRONICS WEB FORUMSsp; --> h=====================
| Explore the seven wonders of the world Learn more!
57.39 KB |
304 Time(s) |
mikenjulie.parkin(at)btop Guest
Posted: Fri Apr 27, 2007 12:45 pm Post subject: Warp Drive propeller blades |
Reminds me of the final instruction before entering the examination room - RTFQ!!! (Read the question)
regards,
[quote] | Quote: | <?fontfamily><?param Tahoma><?x-tad-bigger> Thats just it Graham, they DON'T work at all speeds we fly, only the lower speeds.<?/x-tad-bigger><?/fontfamily>
<?fontfamily><?param Tahoma><?x-tad-bigger>I gained 20 mph on the top end and lost no climb from the WD by going to a custom designed<?/x-tad-bigger><?/fontfamily>
<?fontfamily><?param Tahoma><?x-tad-bigger>fixed pitch prop.<?/x-tad-bigger><?/fontfamily>
<?fontfamily><?param Tahoma><?x-tad-bigger> <?/x-tad-bigger><?/fontfamily>
<?fontfamily><?param Tahoma><?x-tad-bigger> Glenn
<?param Tahoma><?x-tad-bigger>> It's amazing that these props work at all at the speeds we fly, they <?/x-tad-bigger><?/fontfamily>
<?fontfamily><?param Tahoma><?x-tad-bigger>> were designed and developed on Microlights.<?/x-tad-bigger><?/fontfamily>
<?fontfamily><?param Tahoma><?x-tad-bigger>> Graham<?/x-tad-bigger><?/fontfamily>
| [b]
fklein(at)orcasonline.com Guest
Posted: Fri Apr 27, 2007 3:24 pm Post subject: Warp Drive propeller blades |
Mike...I don't get your drift...could you explain further?
Fred
A194
On Friday, April 27, 2007, at 01:44 PM, Mike Parkin wrote:
regards,
Posted: Fri Apr 27, 2007 4:16 pm Post subject: Warp Drive propeller blades |
Now isn't that a coincidence! Craig also makes one of the favourite EZ
propellers, (3 blade). The other EZ favourite is Gary Hertzler's 2 blade
"Silver Bullet" AFAIK both these guys use computer optimisation.
BTW waiting list for either is quite long. Market opportunity for
someone. Wish I was a bit younger!
Graham
| Quote: | Hey Jeff - I am using a Catto fixed pitch 3 blade, 64 x 62 on my 125
hp EA81 powered
the Catto vs other
Posted: Fri Apr 27, 2007 4:19 pm Post subject: Warp Drive propeller blades |
Mike
you're getting as cryptique as me! Which question, preis or value?
Graham
Mike Parkin wrote:
regards,
fixed pitch prop.
Glenn
fly, they
> Graham
Graham Singleton
Tel: +441629820187
Mob: +447739582005
Posted: Fri Apr 27, 2007 9:46 pm Post subject: Warp Drive propeller blades |
Fred,
It's my twisted mind - gets worse as I get older. What amused me is how a 'thread' is subtly changed with each email.
Graham wrote -
" It's amazing that these props work at all at the speeds we fly, they were designed and developed on Microlights. "
(---that these props work at all ------- AT the speeds we fly.)
Glenn replied -
" Thats just it Graham, they DON'T work at all speeds we fly.....".
I'm sorry, I blame my english teacher with the 'supersonic' board rubber (eraser in american).
regards,
Mike
Do not archive.
Posted: Sat Apr 28, 2007 12:59 pm Post subject: Warp Drive propeller blades |
Regarding Craig Catto's props, in my email exchanges with him, Craig
has been very leery of the Rotax hub due to the forces his 3 bladed
wood props generate; he much prefers, at a minimum, a SAE 1 hub/bolt
circle for adequate bearing.
Fred
A194
On Friday, April 27, 2007, at 05:16 PM, Graham Singleton wrote:
blade "Silver Bullet" AFAIK both these guys use computer optimisation.
Graham
> 125 hp EA81 powered
gcrowder2
Posted: Sun Apr 29, 2007 6:41 am Post subject: Warp Drive Propeller Blades |
Hey Fred - Saber Manufacturing in Grandbury Texas has a line of adapters and hub
extensions available that can mount anything to anything! They will make anything you
need.
http://www.sabermfg.com/extensions.htm
Glenn
Fred
A194
Posted: Sun Apr 29, 2007 8:18 am Post subject: Warp Drive Propeller Blades |
Thanks Glenn...this info goes direct to my prop file...my only wish is
that I would need the info today, rather in the fuzzy future.
Fred
On Sunday, April 29, 2007, at 07:40 AM, glenn crowder wrote:
| Quote: | Hey Fred - Saber Manufacturing in Grandbury Texas has a line of
adapters and hub
make anything you
need.
Glenn
creightonious
Posted: Mon Apr 30, 2007 7:21 am Post subject: Warp Drive propeller blades |
Regarding Craig Catto's comments re: Rotax hub circle...
After reading Paul Lipps' short article it appears to me that the lack of racking and twisting and the reduced mass at the tips might go a long way toward minimizing the loads at the hub which give Craig the fantoids.
Creighton Smith
A036 Half done
_________________ Creighton Smith
A 036 |
