trimmed too much flap flange
asarangan(at)YAHOO.COM
PostPosted: Sun Apr 22, 2007 1:12 pm    Post subject: trimmed too much flap flange Reply with quote
I trimmed a little too much flange off the tip end of the flap. Now the
gap between the aileron and flap is about 15mm instead of the
recommended 3-5mm. I am assuming this is not such a big deal, but would
like to rebuild the flange anyway to reduce the gap. I was thinking of
applying a few strip of bid on the old flange, to rebuild it. Any
thoughts if I am overlooking something?
sidsel.svein(at)oslo.onli
PostPosted: Sun Apr 22, 2007 10:47 pm    Post subject: trimmed too much flap flange Reply with quote
Andrew,
I recommend you combine this fix with fillling the void to make the tip end
"square" (not protruding flanges). See attached sketch,
illustrating how to make up for the too large cut-off at the same time.
I did this on the ailerons (with cut-out for the control rod and bolt at
root end) and the adjoining part of the wing tip. Also the tip end of the
flaps, as well as the tip end of the anti-servo trim planes and the
adjoining part of the horizontal stabilator. This looks much nicer than the
flanges protruding out (IMHO), and adds very little weight.
If the flanges on the other surfaces are already cut to the correct
clearance, cut back a little more to allow for the bid plies, filler and
paint.
Svein
LN-SKJ
control_surface_end.pdf
 Filename:  control_surface_end.pdf
 Filesize:  10.28 KB
 Downloaded:  267 Time(s)
