601 Canopy Latches and Towbar attachment
nfivesl(at)yahoo.com
PostPosted: Mon Feb 06, 2006 8:24 am    Post subject: 601 Canopy Latches and Towbar attachment Reply with quote
Larry, Al, Trevor, Brandon, Neil and others:
Thanks for all the replies on and off-list about the
latches. I ordered them directly from Spaenaur and it
was $50 for both sides and a few extra strikers ($50US
was their minimum order). ZAC wants $370 for the pair
of assemblies.
Also, thanks for the lively discussion last week (or
the week before) on towbar attachments. I made one
last weekend with my little mill/lathe. It was a fun
project and I think it will work well. It gave me
something to do while my crankshaft is away.
Here's a photo:
http://www.cooknwithgas.com/2_4_06_Towbar.JPG
Happy Building,
Scott Laughlin
601XL/Corvair
<larrymc(at)qconline.com>
*Scott,
SPAE-NAUR company, Toronto. They can be purchased
from the Windsor
>> >Factory Supply 519-966-2202. The part numbers
are 099-031 for the left
>hand
>> >one and 099-030 for the right hand one. They
cost $36.40 Canadian each.
Larry McFarland - 601HDS
japhillipsga(at)aol.com
PostPosted: Mon Feb 06, 2006 12:20 pm    Post subject: 601 Canopy Latches and Towbar attachment Reply with quote
Scott, the way I made a tow bar attachement was to drill holes in the ends of the front axel and thread them. Then I used a 10 mm barrel insert and bolted it on each end and redrilled the carter pin hole. Works great, looks good. Best regards, Bill
PostPosted: Tue Feb 07, 2006 5:12 am    Post subject: 601 Canopy Latches and Towbar attachment Reply with quote
Malcolm:
I plan to weld it to the frame. Some modification to
the latch is required also from what I understand.
sl
--- Hunt Malcolm <Malcolm.HUNT(at)networkrail.co.uk>
wrote:
On point that is not clear from the manual, is the
lock welded to the
canopy frame? If not how is it fixed.
