cowl
rflick(at)chilitech.net
PostPosted: Mon Feb 06, 2006 8:07 am    Post subject: cowl Reply with quote
anyone have a cowl for my 601 hds with a subaru? thanks ralph
frank.hinde(at)hp.com
PostPosted: Mon Feb 06, 2006 8:39 am    Post subject: cowl Reply with quote
I believe it's the same cowl as for the Rotax with a couple of bumps for
the exhaust pipe elbows.
If you have the satndard cowl you should be able to make it fit
Mine fitted very poorly incidently, but no worse than anyone elses.
Frank.
Larry McFarland
PostPosted: Mon Feb 06, 2006 8:54 am    Post subject: cowl Reply with quote
Ralph,
There are two or more types of cowl that fit Subaru depending on the
engine supplier/redrive
etc. NSI has one as does Zenith for the Stratus, but they're a bit
different in the way they're
fitted out. Which do you have?
Larry McFarland
Larry McFarland - 601HDS - Stratus
japhillipsga(at)aol.com
PostPosted: Mon Feb 06, 2006 12:15 pm    Post subject: cowl Reply with quote
Bill, I know that Jim Weston has an HDS with a Sub engine. His plane is at Thomaston Airport, Georgia (OPN) and he has been on this thread in the past. Good guy and nice ac. Contact him by checking the archive for his e mail address. Best of luck, Bill
