kearney(at)shaw.ca Guest
Posted: Fri Apr 20, 2007 6:17 am Post subject: Trimming Al on Centre Bulkhead |
Hi
After a bit of a build break due to work / vacations / sprained wrist, I am ready to start on my fuse kit.
One of the first steps is to trim material from the web and flange of the centre bulkhead. Given that this is not a piece I want to mess up, I am interested in advice on the best way to proceed. I do have a “nibbler” and could “rough out” the areas first and then finish with a file. Are there better ways?
Whatever method I plan to use, I intend to practise on scrap first.
Any comments / advice welcome.
Cheers
Les
rene(at)felker.com Guest
Posted: Fri Apr 20, 2007 6:39 am Post subject: Trimming Al on Centre Bulkhead |
Les, this is just from memory, but I have kit 322 and I think my holes were already the right shape and size…….but then again I may be thinking of something else…
Rene' Felker
N423CF
40322
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Friday, April 20, 2007 8:15 AM
To: RV10
Subject: Trimming Al on Centre Bulkhead
Hi
Cheers
Les
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
Posted: Fri Apr 20, 2007 6:58 am Post subject: Trimming Al on Centre Bulkhead |
Rene
The plans call for trimming a semi circle on the top edge of the bulkhead web as well as oval shaped portion (1/2) of the bulkhead flange.
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker
Sent: April-20-07 8:39 AM
Subject: RE: RV10-List: Trimming Al on Centre Bulkhead
Rene' Felker
N423CF
40322
801-721-6080
To: RV10
Subject: RV10-List: Trimming Al on Centre Bulkhead
Hi
Cheers
Les
[/b]http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com[/b] | Quote: | | [b] RV10-List Email Forum - | 01234567890
jeff(at)westcottpress.com Guest
Posted: Fri Apr 20, 2007 8:38 am Post subject: Trimming Al on Centre Bulkhead |
Hi Les,
I'm Kit number 40304 and my holes were the right shape and size as well. The plans call for you to make sure the holes are the right size. I think when you get down to it, you'll be pleasantly surprised to find that that work is already done
Jeff Carpenter
HIDs, Heated Pitot, Fuse, Bottom Wing Skins
... too much stuff at once
On Apr 20, 2007, at 7:56 AM, Les Kearney wrote:
Rene
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rene FelkerSent: April-20-07 8:39 AMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: RE: RV10-List: Trimming Al on Centre Bulkhead
Rene' Felker
N423CF
40322
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Les KearneySent: Friday, April 20, 2007 8:15 AMTo: RV10Subject: RV10-List: Trimming Al on Centre Bulkhead
Hi
Cheers
Les
0[/b] |
jchang10
Posted: Fri Apr 20, 2007 8:55 am Post subject: Trimming Al on Centre Bulkhead |
Yes, just confirmed the same for me. All my holes are pleasantly already
there. Phew!
builder # 40533
center section # 10-495
Jae
(Wondering why the heck i didn't get the QB kit)
Jeff Carpenter wrote:
| Quote: | Hi Les,
Jeff Carpenter
> Rene
> Cheers
> Les
> #40643
> Do not archive
> *From:* owner-rv10-list-server(at)matronics.com
> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rene Felker
> *Sent:* April-20-07 8:39 AM
> *To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
> *Subject:* RE: Trimming Al on Centre Bulkhead
> Rene' Felker
> N423CF
> 40322
> 801-721-6080
> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Les Kearney
> *Sent:* Friday, April 20, 2007 8:15 AM
> *To:* RV10
> *Subject:* Trimming Al on Centre Bulkhead
> Hi
> Cheers
> Les
> http://forums.matronics.com*
> *RV10-List Email Forum -*
> *http://www.matronics.com/Navigator?RV10-List*
> *http://forums.matronics.com*
> ** - The RV10-List Email Forum - class="Apple-converted-space"> --> http://www.matronics.com/Navigator?RV10-List - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> http://forums.matronics.com**
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Posted: Fri Apr 20, 2007 8:59 am Post subject: Trimming Al on Centre Bulkhead |
Jeff
I am referring to step # 1 on page 25-3 of the plans. It is not holes I am referring to but two cut outs.
In any event, I don’t plan to do anything until I am certain of a) what is required and b) how to do it properly.
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter
Sent: April-20-07 10:37 AM
Subject: Re: RV10-List: Trimming Al on Centre Bulkhead
Hi Les,
Jeff Carpenter
Rene
Cheers
Les
#40643
Rene' Felker
N423CF
40322
801-721-6080
To: RV10
Hi
Cheers
Les
| Quote: | | RV10-List Email Forum -http://forums.matronics.com - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> http://forums.matronics.com[/b] | 0123456789012
Posted: Fri Apr 20, 2007 9:47 am Post subject: Trimming Al on Centre Bulkhead |
The cut outs are already made...
On Apr 20, 2007, at 9:58 AM, Les Kearney wrote:
Jeff
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jeff CarpenterSent: April-20-07 10:37 AMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Re: RV10-List: Trimming Al on Centre Bulkhead
Hi Les,
Jeff Carpenter
Rene
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rene FelkerSent: April-20-07 8:39 AMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: RE: RV10-List: Trimming Al on Centre Bulkhead
Rene' Felker
N423CF
40322
801-721-6080
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Les KearneySent: Friday, April 20, 2007 8:15 AMTo: RV10Subject: RV10-List: Trimming Al on Centre Bulkhead
Hi
Cheers
Les
[/b]http://www.matronics.com/Navigator?RV10-List | Quote: | | Quote: | | RV10-List Email Forum -http://forums.matronics.com |
0123456789012
3 |
Posted: Fri Apr 20, 2007 12:03 pm Post subject: Trimming Al on Centre Bulkhead |
Hmmm
Not on mine. Unless I am missing something but I don’t think so ….
Cheers
Les
Sent: April-20-07 11:47 AM
Jeff
Cheers
Les
#40643
Hi Les,
Jeff Carpenter
Rene
Cheers
Les
#40643
Rene' Felker
N423CF
40322
801-721-6080
To: RV10
Hi
Cheers
Les
[url=http://www.matronics.com/Navigator?RV10-List][/url] [/b][b] - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> http://forums.matronics.com RV10-List Email Forum -http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com [/quote]012345678901234
seipel(at)seznam.cz Guest
Posted: Fri Apr 20, 2007 1:41 pm Post subject: Trimming Al on Centre Bulkhead |
Just draw it on there using the dimensions in the plans and use whatever
method appeals to you the best to cut it out. I used a dremel with a
sanding drum. Debur the edges and prime it if you want and you're done.
I don't see how you can mess it up unless you cut outside the line you drew.
PJ
RV-10 #40032
Les Kearney wrote:
Hmmm
Cheers
Les
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jeff
Carpenter
*Sent:* April-20-07 11:47 AM
*Subject:* Re: Trimming Al on Centre Bulkhead
Jeff
Cheers
Les
#40643
Posted: Fri Apr 20, 2007 2:21 pm Post subject: Trimming Al on Centre Bulkhead |
Hi
I just went to the aviation dept of the local hardware store and picked up a
couple of dremel attachments to do the job.
That sounds like the way to go but I will practise on scrap first. I'm a bit
edgy when it comes to expensive bits of the kit.
Cheers
Les
wcurtis(at)nerv10.com Guest
Posted: Fri Apr 20, 2007 5:40 pm Post subject: Trimming Al on Centre Bulkhead |
As been mentioned many times before, you kit number only refers to your empennage kit and has no bearing on what version of wing or fuselage kit you have. That being said, for the SB fuselage, I believe you still have to cut the spar carry through for the landing gear weldment and enlarge the holes for the rudder cables.
See here:
http://wcurtis.nerv10.com/08fuselage/fuselage01a.html
and here:
http://wcurtis.nerv10.com/08fuselage/fuselage01d.html
I used a plain old jig saw.
http://wcurtis.nerv10.com/08fuselage/fuselage01e.html
William
