herbgh
Posted: Thu Apr 19, 2007 5:34 am Post subject: Firestar lift struts |
Nuther subject..
I am building a set of single lift strut wings for my Firefly..
finally getting my butt in gear after a long and hard winter..
Question: what dia and wall thickness are the lift struts on a
Firestar.. older , single seat model would be fine... Herb
WhiskeyVictor36(at)aol.co Guest
Posted: Thu Apr 19, 2007 6:53 pm Post subject: Firestar lift struts |
In a message dated 4/19/2007 9:34:56 A.M. Eastern Daylight Time, herbgh(at)juno.com writes:
| Quote: | Question: what dia and wall thickness are the lift struts on a
Firestar.. older , single seat model would be fine |
Herb,
Here are the dimensions of the early Original FireStar model:
Strut = 2024-T3 Alum Tube 1-1/4" OD X .058" wall, with length to be determined at assembly.
Internal Sleeve = 2024-T3 Alum Tube 1-1/8" OD X .058" wall X 36" long.
Internal sleeve is to be centered in the strut and held in place with one 1/8" X 1/8" rivet. It is important to place the rivet 41-1/2" from the top end of the strut AND the rivet head toward the rear (or trailing edge) of the strut.
Lift strut fittings are attached to each end of the strut with 1/8" X 1/2" rivets. 5 rows of 5 rivets per row, spaced evenly around the circumference of the tube.
Hope this helps.
Bill Varnes
Original Kolb FireStar
Audubon NJ
See what's free at AOL.com.
herbgh
Posted: Thu Apr 19, 2007 8:26 pm Post subject: Firestar lift struts |
Thanks Bill
I hoped that they were 6061 t6 since I have quite an assortment of that...I will likely talk to the Kolb folks when I go that way next week.. maybe Bryan also.. He built a single lift strut Firefly some time back.. Herb
On Thu, 19 Apr 2007 22:53:09 EDT WhiskeyVictor36(at)aol.com (WhiskeyVictor36(at)aol.com) writes:
[quote] In a message dated 4/19/2007 9:34:56 A.M. Eastern Daylight Time, herbgh(at)juno.com writes:
Herb,
Hope this helps.
Bill Varnes
Audubon NJ
Posted: Fri Apr 20, 2007 7:58 am Post subject: Firestar lift struts |
In a message dated 4/20/2007 12:26:56 A.M. Eastern Daylight Time, herbgh(at)juno.com writes:
| Quote: | | I hoped that they were 6061 t6 since I have quite an assortment of that |
Herb,
Just for your information, the specification of 2024-T3 which I gave you was taken directly from the plans and material packing list. I agree, it would be best to ask someone at Kolb.
Bill Varnes
Audubon NJ
herbgh
Posted: Fri Apr 20, 2007 9:08 am Post subject: Firestar lift struts |
Hi Bill
Not doubting your word.. I knew you were correct and would not speculate on a critical part of the airframe.. Thanks again,,,
Given the difference in gross wt; I need to chat with Kolb and I will be stopping by there next week.. Will likely buy the material there. too.
As I said , Bryan built a single lift strut firefly and I need to chat with him on some details.. Herb
On Fri, 20 Apr 2007 11:57:52 EDT WhiskeyVictor36(at)aol.com (WhiskeyVictor36(at)aol.com) writes:
[quote] In a message dated 4/20/2007 12:26:56 A.M. Eastern Daylight Time, herbgh(at)juno.com writes:
Herb,
Bill Varnes
Audubon NJ
Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Sat Apr 21, 2007 3:42 pm Post subject: Re: Firestar lift struts |
I dont know if you will like these, but I built single struts for my FireFly a couple of years ago. They made a world of difference.
here is a link to the strut mod page on my FireFly builders site.
http://www.geocities.com/dagger369th/strut_mod.htm
I consulted with Dennis Souder on the design of the attachment fittings, and followed his advise accordingly.
They have over 100 hours on em now....wouldnt even consider going back.
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
d-m-hague(at)comcast.net Guest
Posted: Sat Apr 21, 2007 4:59 pm Post subject: Firestar lift struts |
At 07:42 PM 4/21/2007, Don G wrote:
FireFly a couple of years ago. They made a world of difference...
What is the advantage to the single strut? Less drag I suppose, but the
loss of stiffness (allowing wing twist) would seem to be a bad thing.
-Dana
My software never has bugs. It just develops random features.
herbgh
Posted: Sat Apr 21, 2007 5:11 pm Post subject: Firestar lift struts |
Don
I remember your conversion.. and would have copied it save that I am
using h sections in my spar and the thru bolt.. using Ultra star ribs and
the ultrastar h section..
Do you recall the major and minor axis for the streamlined tubing? I
am guessing that they buy it from Mary Carlson.. She has the dies for
two sizes..Herb
On Sat, 21 Apr 2007 16:42:52 -0700 "Don G" <donghe(at)one-eleven.net>
writes:
herbgh
Posted: Sat Apr 21, 2007 5:22 pm Post subject: Firestar lift struts |
Dana
I suspect that the reason for the dual lift strut on the firefly was
for weight considerations? I am betting that Homer and Dennis built
several fireflies before they got one under part 103...?? A fantastic
little bird , I might add!! Love mine...
I do not follow the loss of stiffness idea? The wing is built like
all other Kolbs which have a single strut... Same spar as the Firestar..
If there is a problem, I need to know ... I am esentially building a
shortened Ultrastar or Firestar wing... Herb
On Sat, 21 Apr 2007 20:58:36 -0400 Dana Hague <d-m-hague(at)comcast.net>
writes:
my
the
thing.
-Dana
possums(at)bellsouth.net Guest
Posted: Sat Apr 21, 2007 5:40 pm Post subject: Firestar lift struts |
At 08:58 PM 4/21/2007, you wrote:
>my FireFly a couple of years ago. They made a world of difference...
the loss of stiffness (allowing wing twist) would seem to be a bad thing.
-Dana
Ok - since it's Saturday and after 5:00 PM and most of the hard core
Kolb guys have gone to
"Sun & Fun" , I'll comment here. My plane (half Kolb/half Fergy) and
has connections for
both the single and double struts. You supposed right, less drag is
the advantage,
Loss of 8 mph top end.
Wing twist is why they were ever there to start with. But it is very
hard to twist the original Kolb wing/ribs. My plane
has original Kolb wing/ribs. However, I do put the doubles on
occasionally when I might decide to do
something outside the envelope. Fergy has taken them off all their
planes (if you would want to know).
40.66 KB |
485 Time(s) |
a58r(at)verizon.net Guest
Posted: Sat Apr 21, 2007 5:48 pm Post subject: Firestar lift struts |
Re: Ff double struts. Need the extra drag to comply w/ 103. dang
shame, though.
regards,
Bob N. FireFly 070 Old Kolb
do not archive...or do we do that anymore/
Posted: Sat Apr 21, 2007 5:59 pm Post subject: Firestar lift struts |
At 09:20 PM 4/21/2007, herbgh(at)juno.com wrote:
| Quote: | I suspect that the reason for the dual lift strut on the firefly was
Having dual struts resists twisting of the wing, and the expense of drag
(vs. a single strut). If there's only one strut (as in the Ultrastar), the
wing structure itself has to resist all the twisting forces (as from
aileron deflection). A single strut attaching at two points is no stiffer
than a single strut attaching at one point (unless the strut is VERY stiff,
with a rigid connection to the crossbar).
-Dana
At 09:47 PM 4/21/2007, Bob Noyer wrote:
shame, though.
Ah HA! Is that really why? Tricky, very tricky...
-Dana
Posted: Sat Apr 21, 2007 6:21 pm Post subject: Firestar lift struts |
At 09:58 PM 4/21/2007, you wrote:
| Quote: | >Re: Ff double struts. Need the extra drag to comply w/ 103. dang
>shame, though.
-Dana
YES -
herbgh
Posted: Sat Apr 21, 2007 9:25 pm Post subject: Firestar lift struts |
Hi Dana
Understand now... The Firefly does not have dual lift struts in the
normal sense.. They both attach to the main 5 inch spar...
And I see in a later post what I now recall .. To add drag... part 103
consideration.. Herb
On Sat, 21 Apr 2007 21:56:56 -0400 Dana Hague <d-m-hague(at)comcast.net>
writes:
firefly was
like
Firestar..
drag
Steve Boetto
Posted: Tue Apr 24, 2007 6:47 am Post subject: Firestar lift struts |
Sounds like you Guys got this one sorted out.
Yes the two struts were for drag for part 103. Drag values were given for different parts and tubes for the paper calculations.
A conversion to a single strut with ONE connection would require a new wing with an H section.
Don, I like your mod, might use it on my FF. I get plenty af drag with my Floats.
This info comes via Bryan Melborn.
Steve B
herbgh
Posted: Tue Apr 24, 2007 8:07 am Post subject: Firestar lift struts |
Steve
I installed Ultrastar H sections in my new Firefly wings.. Gonna use whatever lift strut/hardware Bryan used when he built the Fly for a guy in east Tenn. I will do a bit of streamlining on the back part of the struts .
Herb
On Tue, 24 Apr 2007 10:47:01 EDT N27SB(at)aol.com (N27SB(at)aol.com) writes:
[quote] Sounds like you Guys got this one sorted out.
Steve B
Steve Boetto
Posted: Tue Apr 24, 2007 10:34 am Post subject: Firestar lift struts |
In a message dated 4/24/2007 12:08:09 P.M. Eastern Standard Time, herbgh(at)juno.com writes:
| Quote: | Steve
I installed Ultrastar H sections in my new Firefly wings. Gonna use whatever lift strut/hardware Bryan used when he built the Fly for a guy in east Tenn. I will do a bit of streamlining on the back part of the struts .
Herb
Hi Herb
Sounds like the way to go if you built you wings that way.
steve
Don G
Posted: Wed Apr 25, 2007 1:22 pm Post subject: Re: Firestar lift struts |
Herb,
((Do you recall the major and minor axis for the streamlined tubing? I
two sizes..Herb ))
No I dont recall the sizes I am afraid, I bought it from Wicks, and if I recall they told me it was the same size that CGS uses on the Hawk.
Probably 3 inchs or so major....but I will measure it next time I get to the hangar for you.
Steve....the drag reduction you get is pretty significant. And you might consider a smaller size in steel streamlined tubeing, Could work even better. I Believe John Hawk told me once he used that on a Firestar with good results. In fact, As I remember, I got the Idea from him, and after I talked to Dennis Souder about the reasons for the dual struts in the first place. I had heard that it was for part 103 compliance and I didnt really believe that, So I called Dennis and he explained the whole deal to me.
Considering you are hauling around those Pontoon logs, It oughtta help!!
I can tell you this, My FireFly is heavy, and my TOW sometimes is 550lbs and even at that weight, it will do 90mph WOT with a 2 blade 60 inch IVO set at 6250 static and 6450 WOT inflight. Cruises at a solid 75 around 5600
Naturally thats not all due to the struts, but the combination of struts, ducktail and enclosure of the cage all around.
I had wheelpants on it for awhile, but they didnt seem to help it anymore. And when I put Hydraulic brakes on it with bigger tires, I took them off..(wouldnt fit anymore) didnt seem to notice a speed reduction. Obviously I dont fly it that fast very often. But when the need arises to show off, It does a good job of it.
Last summer, I was leaving a fly-in and took off behind an L-2 and a Luscombe. They were traveling together. I kinda got in that show off mood, and about 5 miles out from the airfeild, I caught up and passed them. The guy in the Luscombe joined in and flew with me for a few miles, but the guy in the L2 was left in the dust! After a while, the guy in the Luscombe called a goodbye on the radio and went back to find his partner, who was long outta sight, but not out of radio range. He kept asking the Luscombe pilot...IS that a damn ultralight up there?????
They talk about that RV grin...but that day I had a Kolb smile that lasted a long, long time!
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
herbgh
Posted: Wed Apr 25, 2007 4:59 pm Post subject: Firestar lift struts |
Don
Thanks... I will going by the Kolb factory next week.. Keep delaying !
Hope to get some tubing and such.. Better email Travis ! Herb
On Wed, 25 Apr 2007 14:22:05 -0700 "Don G" <donghe(at)one-eleven.net>
writes:
Herb,
I
for
two sizes..Herb ))
Hawk.
