gbthacker(at)hotmail.com Guest
Posted: Sun Apr 15, 2007 7:14 pm Post subject: Firestar II trailer.....thumbs |
What would you guys suggest as the minimum interior trailer length for my 97
Firestar II?
Gary
Souderton,PA
Download Messenger. Join the i’m Initiative. Help make a difference today.
http://im.live.com/messenger/im/home/?source=TAGHM_APR07
lcottrell
Posted: Sun Apr 15, 2007 7:41 pm Post subject: Firestar II trailer.....thumbs |
25 feet and as wide as you can legally own. There is no such thing as too
much room. I always used mine to carry camping stuff, and wished that I had
built it bigger and longer. Carrying a quad along with the plane would be
really nice. A nice little self contained work area and storage area could
be really handy. When I built my trailer I set the box inside of the wheels
reasoning that the wheel wells would limit storage anyway. If I had it to do
over I would have made it that much bigger.
Larry, Oregon
Posted: Mon Apr 16, 2007 6:01 am Post subject: Firestar II trailer.....thumbs |
Hi Larry
We are getting ready to move. I looked at getting a moveing company to move
use but for a bit more I can buy a trailer move myself and then have the
trailer to move and store the FS. I was thinkin a 24' but maybe a 28 would
be better. I don't want to get to big.
Gary
Souderton,Pa.
[quote]From: "Larry Cottrell" <lcottrell(at)fmtcblue.com>
Reply-To: kolb-list(at)matronics.com
To: <kolb-list(at)matronics.com>
Subject: Re: Firestar II trailer.....thumbs
Date: Sun, 15 Apr 2007 21:40:27 -0600
do over I would have made it that much bigger.
Larry, Oregon
lcottrell
Posted: Mon Apr 16, 2007 8:04 am Post subject: Firestar II trailer.....thumbs |
Hi,
You may hate to haul it, but the extra room will be most appreciated when
you get there.
Larry,Oregon
| Quote: | be better. I don't want to get to big.
Gary
Souderton,Pa.
Ralph B
Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
Posted: Mon Apr 16, 2007 8:10 am Post subject: Re: Firestar II trailer.....thumbs |
Try this one. It's 5'X8'.
Ralph
136.64 KB |
520 Time(s) |
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
rowedenny(at)windstream.n Guest
Posted: Mon Apr 16, 2007 9:29 am Post subject: Firestar II trailer.....thumbs |
Ralph,
I would think that set up is putting too much load on the tail boom tube
where the support holds it. Any bumps or side loads are going to put a
tremendous loads on the tail.
Denny Rowe
Paul Petty
Ralph B
Posted: Mon Apr 16, 2007 9:58 am Post subject: Re: Firestar II trailer.....thumbs |
Denny, I've been trailering on this for over 20 years. The reason it doesn't dent the main fuse tube is because the trailer is a single axle and has enough cushion to absorb the bumps in the road. This design would not work for a large 2-axle trailer and would dent the tube. I know this as it happened to a friend of mine. The pedestal support is 6" X 1" with carpet remnant for the tube.
Ralph
Kolb Kolbra 912uls
N20386
550 hours |
Paul Petty
Posted: Mon Apr 16, 2007 10:25 am Post subject: Re: Firestar II trailer.....thumbs |
Ralph,
Wow 20 years well I guess it's wel proven. Ever had any close calls like it getting blown over? How far and how fast do you go with in?
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
jbhart(at)onlyinternet.ne Guest
Posted: Mon Apr 16, 2007 11:08 am Post subject: Firestar II trailer.....thumbs |
At 09:10 AM 4/16/07 -0700, you wrote:
Ralph,
Elegant solution!
Jack B. Hart FF004
Winchester, IN
Ralph B
Posted: Mon Apr 16, 2007 11:35 am Post subject: Re: Firestar II trailer.....thumbs |
It's small and easy to maneuver with the single axle. It has negative tongue pressure, which means when I remove it from the ball hitch, the tongue goes up and it rests on the tailwheel. If you think it would be unstable on the road, it's not. This is because the slipstream acts like a huge rudder going down the road and actually stabilizes it. I've trailered though some heavy winds with this. The faster you go, the more stable it becomes. In a good wind I can feel the back of the car moving a little. I only go about 7 miles to the strip, so it's not too bad. I wouldn't want to trailer it for long distances, but I'll bet I could. Here it is in my garage. I haven't ever had any problems with this, but I have to make sure the trailer wheels are chocked and the tongue prop is secure before unloading. If it moves, the wings can get dented easily. I have to be very careful.
Ralph
118.76 KB |
506 Time(s) |
Kolb Kolbra 912uls
N20386
550 hours |
Ralph B
Posted: Mon Apr 16, 2007 6:22 pm Post subject: Re: Firestar II trailer.....thumbs |
I found a few more Firestar trailer pics.
Ralph
170.28 KB |
573 Time(s) |
130.42 KB |
499 Time(s) |
70.8 KB |
517 Time(s) |
Kolb Kolbra 912uls
N20386
550 hours |
