jindoguy(at)gmail.com Guest
Posted: Sat Apr 14, 2007 10:58 am Post subject: Warp Drive prop inertia concerns |
Mike, et al, Since you haven't installed your new Warp Drive prop yet, why not take an hour and test it's inertia per Rotax service information bulletin SI 11 UL 91E? It's really easy to do, all it takes is a small piece of plywood, some safety wire and a stop watch. Better to know you're within limits, than guess, eh?
You can download SI 11 UL 91E from the Rotax owners web site.
Rick
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
John Williamson
Joined: 10 Jan 2006 Posts: 146 Location: Arlington, TX
Posted: Sat Apr 14, 2007 12:02 pm Post subject: Re: Warp Drive prop inertia concerns |
It took over 30 minutes to find the document you were referring to on the Rotax Owners web site.
It can't be very relevent any more since the real Rotax site doesn't carry it:
http://www.rotax-aircraft-engines.com/a_searchdoc.aspx
To make it easier for those that are interested, I have uploaded the .pdf file with this post.
It is listed as SI-11-1991 and it's old number is SI 11 UL 91 E.
I have zero concerns about running my 68 inch 3 blade Warp Drive tapered tip prop with nickel leading edges on my Rotax 912ULS. It seems to make the Kolbra perform fairly well!
11ul91.pdf |
535.11 KB |
540 Time(s) |
_________________ John Williamson
Arlington, TX
Kolbra, 912ULS, 1640 hours
http://home.tx.rr.com/kolbrapilot |
Posted: Sat Apr 14, 2007 2:19 pm Post subject: Warp Drive prop inertia concerns |
| John Williamson
Hi John W/Gang:
I'm not going to lose any sleep over flying Warp Drive Props with
nickle edges either. After 13 years and 2,500+ hours split between
two engines, without showing any wear in either engine to either gear
box, I have convinced myself that my 912ULS will preform as usual.
Same goes for my oil and oil filters.
I don't advise anyone to use anything I do. Based on the type of
flying, the places I have flown, and the places I plan to fly, I'm not
going to use a product that I have any doubts about, any at all.
I've got antique tractors that are 71 years old that still don't know
what an oil filter is and never will.
Plugging along getting the mkIII flyable in some very adverse weather.
_________________ John Hauck
Titus, Alabama |
Roger Lee
Posted: Sat Apr 14, 2007 3:22 pm Post subject: Re: Warp Drive prop inertia concerns |
Hi John,
Were all those hours with a 68"+, nickel edged prop? I don't remember you with the nickeled edge prop.
Your engine will run just like Eric Tucker said, but if the inertia is too much it just causes premature wear.
Tapered tips are better than square tips as they have less mass. Eric warned us away from the nickeled edged props. Too weighty at the tips for the tranny longevity.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Sat Apr 14, 2007 3:42 pm Post subject: Warp Drive prop inertia concerns |
| Roger Lee
Hi Roger:
Don't know if you were addressing the question to John W or me.
If it was me, yes I flew all those hours with two 912's turning 70 and
72" Warps with nickle edges.
John W flies with a 68" Warp Drive and I can not remember if he has
nickle edges or not.
I have successfully completed Eric Tucker's 912 Course three times
now. I have good luck with 912's and get a lot of reliable service
from them.
Like I said in a previous msg, I am not going to do something with my
engine to put my life in jeopardy based on my flying style and the
"serious" areas I fly out West, in Canada, and Alaska.
Titus, Alabama |
JetPilot
Posted: Sun Apr 15, 2007 11:20 am Post subject: Re: Warp Drive prop inertia concerns |
John W,
Why are you only running 68 inch prop ? I would think the 70 or even 72 would perform better on a 912 ULS ...
I also have nickel leading edges on my prop also, I plan on flying through some rain, and they are needed for that, no way do I want go through trying to put and keep leading edge tape on the prop, it sounds like a real pain in the arse from what I have read about it. I am not to worried about the inertia of the prop, there are so many warp drive props in use on 912's and it has never been an issue. I would rather have a prop that will take some abuse and stay together than a lighter one that is in limits, and that I have to worry about comming apart.
Mike
Kolb MK-III Xtra, 912-S |
jbhart(at)onlyinternet.ne Guest
Posted: Sun Apr 15, 2007 12:00 pm Post subject: Warp Drive prop inertia concerns |
At 12:20 PM 4/15/07 -0700, you wrote:
Mike,
Doesn't this void the engine warrenty?
Jack B. Hart FF004
Winchester, IN
JetPilot
Posted: Sun Apr 15, 2007 7:58 pm Post subject: Re: Warp Drive prop inertia concerns |
| jbhart(at)onlyinternet.ne wrote: |
Mike,
Jack B. Hart FF004
Winchester, IN
I have not measured the inertia of the warp drive prop, nor do I know what it is. It would be interesting to know, but I suspect it is in limits. If not, its probably pretty close. I would like to know the number, but in the end I am still going to use my Warp drive prop.
There are many many warp drive props running on Rotax 912's, probably more hours with the warp drive than any other type of prop with no problems reported. What does that tell you ? It tells me not to worry about it.
Now in a pusher configuration, there is always the possiblity of an engine part going through the prop. Would you run a very light prop that would probably throw a blade if a muffler part went through it, ripping the engine from its mounts, just because you are worried about the engine warrenty ? That is a very real concern, it happens.
Mike
DAquaNut(at)aol.com Guest
Posted: Sun Apr 15, 2007 8:56 pm Post subject: Warp Drive prop inertia concerns |
In a message dated 4/15/2007 10:59:48 PM Central Standard Time, orcabonita(at)hotmail.com writes:
| Quote: | Would you run a very light prop that would probably throw a blade if a muffler part went through it, ripping the engine from its mounts, just because you are worried about the engine warrenty ? That is a very real concern, it happens.
Mike
Has this senario actually happened, or, are you just afraid it is going to happen. Is there documentation that these props throw blades with no apparent cause? Do you have your muffler springs safetied along with silicon in them? How about the newer clamps that replace the springs and cant break and go through the prop?
Ed Diebel
See what's free at http://www.aol.com. [quote][b]
JetPilot
Posted: Mon Apr 16, 2007 7:32 am Post subject: Re: Warp Drive prop inertia concerns |
Ed,
Not on a Kolb, but there are quite a history of prop blades being thrown on small experimental aircraft. I found quite a few accidents where prop blades were thrown and the prop, or both the prop and engine was ripped from the plane. I can not find a single fialure of the Kiev prop, but there are so few of them out there it is hard to find any information or user reports for the Kiev. There are even fewer examples of a Kiev prop on the 912-S. I think the Kiev prop would be great on a 2 stroke Rotax, but I dont trust it on the 912-S.
What are the new clamps you are talking about for the muffler ? I have springs with safety wire, but I would like to see the clamps if they are better. Can you point me in the right direction ?
Mike
jstewart(at)inebraska.com Guest
Posted: Mon Apr 16, 2007 10:17 am Post subject: Warp Drive prop inertia concerns |
Warp Drive props have a bat handle on the root of the blade. No way they
can fall out.
J.D. Stewart
UltraFun AirSports, LLC
http://www.ultrafunairsports.com
Ed,
direction ?
Mike
Paul Petty
Posted: Mon Apr 16, 2007 10:44 am Post subject: Re: Warp Drive prop inertia concerns |
J.D.,
I took this from your website hope it's ok.
" LIFETIME GUARANTEE OF SATISFACTION: We have the confidence in our propellers to include a Lifetime Guarantee of Satisfaction with each one. If your Warp Drive Propeller is not to your liking for any reason no matter who might be responsible, and for whatever reason, we will get it right. Warp Drive only wants happy owners."
Pretty gutsy statement from Warp Drive.
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
Posted: Mon Apr 16, 2007 11:07 am Post subject: Warp Drive prop inertia concerns |
Daryl is one of those guys who will back up his statements, too.
J.D.
J.D.,
Paul Petty
Kolbra #12
Ms Dixie
Final assembly!
