		MJKTuck(at)cs.com Guest
				 Posted: Sun Feb 05, 2006 4:36 pm    Post subject: Oil Changes |
				Hi Folks,
 Time to change the oil again. In the past I have cleaned out and refilled the
 main oil tank and changed the oil filter - having been told it wasn't worth
 trying to empty the entire system. I half filled the new filter cartridge
 before putting it on. In the past I have then use a small hand pump to pressurize
 the main tank and then turned the prop a few times - I guess the instructions
 call for this when first filling the system so I have always done this when I
 change the oil. I have to wonder if it is worth the effort?
 What does everyone else do when changing the oil? I have a regular 912UL.
 Martin Tuck
 Europa N152MT
 Wichita, Kansas
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		hagargs(at)earthlink.net Guest
				 Posted: Sun Feb 05, 2006 7:05 pm    Post subject: Oil Changes |
				Martin:
 Ths is from Eric Tucker  the guy from Kodiac research who gives the 3 day
 Rotax class/seminar.
 1. Drain engine / tank
 2. Fill filter half full, don't put on.
 3. Put 3 liters in tank
 4 Turn prop till oil comes out of oil filter  base boss.
 5 Install filter
 6 Verify oil pressure by proping or motoring engine without ignition before
 putting back in service.
 He also recommends that at 100 hr insp. the oil tank is taken apart and
 cleaned.
 Steve Hagar
 A143
 Mesa AZ
 Steve Hagar
  	  | Quote: | 	 		   [Original Message]
  To: <europa-list(at)matronics.com>
  Date: 2/5/2006 5:42:07 PM
  Subject: Oil Changes
  Hi Folks,
 the
  	  | Quote: | 	 		   main oil tank and changed the oil filter - having been told it wasn't
 worth
  	  | Quote: | 	 		   trying to empty the entire system. I half filled the new filter cartridge
 pressurize
  	  | Quote: | 	 		   the main tank and then turned the prop a few times - I guess the
 instructions
  	  | Quote: | 	 		   call for this when first filling the system so I have always done this
 when I
  	  | Quote: | 	 		   change the oil. I have to wonder if it is worth the effort?
  Martin Tuck
  Europa N152MT
  Wichita, Kansas
