davef(at)cfisher.com Guest
Posted: Sat Apr 14, 2007 2:43 am Post subject: Speeds question: Re: CCI VG's on the Avid Flyer STOL |
Larry, Great work on the VG's
What are your GPS speed changes while doing these tests ?
I have a number of VGs from different manufactures here that I have planned to do testing on and hopefully this spring. My IV flies so darn well as it is with out gap seals or VGs that I have been reluctant to really do much. I do like the speed increase thoughts though.
One more thing is what kind of tach are you using ?
I have a rotax tach ( which I am about to take out as it is not accurate at all 200 to 800 rpm variations) and a tiny tach. Also I have a fuel flow meter which in combination will help give more accurate testing.
One more test you should try is Wide open straight and level before and after.
Looking forward to more results and some of my own.
Dave
