Z-11
vaughnray(at)bvunet.net
PostPosted: Fri Apr 13, 2007 9:04 am    Post subject: Z-11 Reply with quote
Dang!
I had not seen Rev 11 of the Z drawings. I will incorporate this into my dual alternator schematic. The internal Rotax alternator will be used as an auxillary, which means the electricity that it generates will be absorbed by the 22mF capacitor unless the 40amp eternal regulator fails. Am I right?
Vaughn Teegarden
mprather(at)spro.net
PostPosted: Fri Apr 13, 2007 10:45 am    Post subject: Z-11 Reply with quote
Vaughn,
I don't think that's precisely right.. Whichever alternator has a
regulator with the highest setpoint voltage (it's unlikely the setpoints
will be exactly equal) will provide all of the system power up to 100% of
the current it's capable of at that voltage. The other alternator will
only deliver power to the system when the system voltage drops below that
alternator's setpoint voltage.
I gather the Rotax alternator is actually a permanent magnet dynamo..
Anytime the system voltage is above the regulator setpoint, the
regulator's connection between the dynamo output and the buss is opened
(gated off). The AC voltage seen on the output of the dynamo will rise to
some peak value and remain there (50V?). I don't think any capacitor is
involved.
Matt-
Dang!
Am I right?
Vaughn Teegarden
nuckollsr(at)cox.net
PostPosted: Fri Apr 13, 2007 2:32 pm    Post subject: Z-11 Reply with quote
At 01:04 PM 4/13/2007 -0400, you wrote:
Dang!
Am I right?
Vaughn Teegarden
Figure Z-11 is a single alternator system. If you want to combine
a robust belt driven alternator with a permanent magnet backup
(like the 18A machine on the Rotax) consider Z-13/8.
The latest revisions of all the Z-drawings is available from
the website at
http://aeroelectric.com/whatsnew.html
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
PostPosted: Fri Apr 13, 2007 2:37 pm    Post subject: Z-11 Reply with quote
Dang!
Am I right?
Vaughn Teegarden
Ooops. I missed the earlier posting with power distribution
diagram. Ignore the earlier post on this thread.
( EVERY day . . . )
PostPosted: Sat Apr 14, 2007 9:04 am    Post subject: Z-11 Reply with quote
have attempted to incorporate the new rev 11 rotax alternator system into my dual alt system, as Mike Gregory suggested. PDF file attached. I have also incorporated several changes made by list members because they made too much sense to ignore. BOB, does this give me security in the air. Thank you all.
Vaughn Teegarden
Europa XS mono, Rotax 914
scan0004.pdf
 Filename:  scan0004.pdf
 Filesize:  66.07 KB
 Downloaded:  423 Time(s)
