Mdkitfox(at)aol.com Guest
Posted: Wed Apr 11, 2007 6:00 pm Post subject: Flaperon Covering Removal |
To all who responded - thank you.
I started off using heat, but got worried about the foam ribs. The chemical route worked. I found a gel stripper that had properties close to those ya'll recommended and it worked. It's from Wal Mart and it took only 15 minutes to attack the adhesive. Then just lift off pieces, rinse and it's done. It's a dirty filthy job, but someone has to do it. I guess it's part of the experience!
Rick
Series V Speedster - N39RW
See what's free at AOL.com.
