CrownLJ(at)verizon.net Guest
Posted: Tue Apr 10, 2007 2:32 pm Post subject: Feul tanks |
I know that aluminum tanks were used previously, and discontinued to cracks. Does anyone know how they were mounted and installed?
The Great Lakes had the same problem, but was solved not by going plastic or fiberglass; but by making the gas tank area between the spar stiffer so the tank wouldn't flex with the stresses. The Great Lakes as you may know is an aerobatic airplane with about a 5' fuel tank occupying the center section. I would think that if plywood under the tank, between the spars would solve the problem for them, shouldn't it work for our application as well?
I am inclined to use aluminum tanks like most of the other airplanes flying. I envision cutting the top out of the existing tank, keeping the bottom, sides, and the compression rib in place and making 2 adjoining small tanks in the space that's left. We are fortunate, as it is still legal to use "real" gas here, and the farmers won't use ethanol, so at least for the time being I'm ok. I do have damage and an unusable tank in the left wing, but I am hoping that I won't have to cross this bridge for some time. (still have 17 usg)
Forgot to mention, I have an Avid, but assume that the wing construction should be similar. Knowing the risks of assuming - I ask for your comments.
larry
dosmythe(at)cox.net Guest
Posted: Tue Apr 10, 2007 3:01 pm Post subject: Feul tanks |
Larry,
Did I miss something? Why do you have one unusable tank? What's wrong with it?
After seeing some plastics fall apart I also feel that plastic might not be the way to go. If it comes to a point that tanks "must" be replaced I think all options need to be laid on the table. Another option "might" be to cut open the tanks and completely lay up the insides with new glass and an epoxy that is proven ethanol safe (what ever that might be). Laying up the tank interiors will make the tank stiffer so don't know if this might add a problem?
One problem that might be bigger than the tanks is the effects of Ethanol on everything else (fuel lines, alum, carbs, filter, etc. et.)
I have a feeling that we are a bit over anxious about the effects of Ethanol but it is worth considering for the future. I can't believe our Government would do something that might be harmful to us. Hmmm, I'm retired Government.
Don Smythe
Posted: Wed Apr 11, 2007 5:38 am Post subject: Feul tanks |
Don,
One of my tanks is leaking bad enough that I don't use it and removed the lines to avoid using it. I don't know if it cracked or was eatened by ethanol. I've never had to use ethanol, but the previous owner did. When I got the airplane, the tanks appeared to be weeping. While disabling the tank, and pulling out the quantity indicator, I looked into real good with a light under the tank. It looked like the was "divots" or just like if you poured gas on strofoam type of texture on the bottom of the tank, and pushing from underneath, was soft. So I am assuming it is damage from ethanol. I have considered what I'll do when/if the other tank fails. Currently, I have a 3 gal plastic header tank (was a chemical applicator tank) and a 14 gal fiberglass wing tank. 99.9% of my flying is local, so I try not to keep fuel in the wing when it's not being used. I typically land with fuel only in the header, and I refuel with as much as I think I'll need before going flying.
Larry
Posted: Wed Apr 11, 2007 11:25 am Post subject: Feul tanks |
Larry,
I believe your description of divits and softness is about the first I've heard. I really don't want it to be the fault of Ethanol for obvious reasons but can't come up with any other thoughts as to what it could have caused that. Maybe the original owner soaked the tanks in MEK for a week to remove Kreem????
Don Smythe
