HDS Cattycorner brace
naumuk(at)alltel.net
PostPosted: Mon Apr 09, 2007 5:37 pm    Post subject: HDS Cattycorner brace Reply with quote
Roy and all-
Roy- no attachment for you pictures. Send them to me direct- I'd like to see them.
All- attached is what I wound up with, which is a slight variation on what Jeff Small did. I'll leave the brace in clecos until I permanently mount the rudder and will cut a cable outlet slot to fit. Also notice that I remembered to get the shrink wrap over the cut cable ends. One of my proudest moments!
Amazing that all of us HD/HDS people have struggled with the same problem for 10 years without a definitive solution!
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
 Filesize:  34.5 KB
 Viewed:  267 Time(s)
 Filesize:  45.51 KB
 Viewed:  253 Time(s)
