scott(at)tnstaafl.net Guest
Posted: Sun Apr 08, 2007 7:01 am Post subject: Home grown VMS Capacitive fuel probe converter |
It appears the VMS and EI probes output a 2Khz 5vdc frequency plus or
minus some freq depending on how much the probe is submerged. These
probes have 3 wires, I would assume one of the wires is the output, one
is a grounded reference. Is the other wire power?
I have found a single chip Freq-2-Voltage convert that only requires a
couple additional resistors, caps and diode to convert 0-10Khz freq to a
0-5 volt output.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010486
Now if I can just find out how to hook up the probes... to get their
output? Anybody know?
sounds a lot cheaper than $400 for the princeton converters..
Scott
Truth : the most deadly weapon ever discovered by humanity. Capable of destroying entire perceptual sets, cultures, and realities. Outlawed by all governments everywhere. Possession is normally punishable by death.
Richard Childers
Posted: Sun Apr 08, 2007 3:19 pm Post subject: Home grown VMS Capacitive fuel probe converter |
I just found out from the BMA forum archives:
"QUOTE"
Indeed, the Probes are a resistance/capacitance circuit that yields a
frequency that varies with the fuel changing the capacitance. When the
probe is hooked to the computer the red is +5v, the black is ground and
the white is the square wave frequency output back to the computer. When
you calibrate your tanks, you will supply frequencies to VM and they
will program the ROM that converts frequencies to gallons.
"UNQUOTE"
So a 5 volt supply is needed to provide voltage to the probes on the red
wire and the 5vdc square wave freq is produced on the white wire...
Freq apx 4Khz empty and 2Khz full.
I'll need to drag my scope down to the hanger to verify this.
I wonder if a current limiter is built into the probe?
Scott
Scott Derrick wrote:
<scott(at)tnstaafl.net>
one is a grounded reference. Is the other wire power?
a 0-5 volt output.
Scott
The only security of all is in a free press. The force of public opinion cannot be resisted when permitted freely to be expressed. The agitation it produces must be submitted to. It is necessary, to keep the waters pure.
Thomas Jefferson to Lafayette, 1823. ME 15:491
