scott(at)tnstaafl.net Guest
Posted: Sun Apr 08, 2007 2:29 pm Post subject: VMS capacitance fuel probes used with Dynon EMS? |
Greg,
Are you using EI or VMS probes or building your own?
Scott
Greg wrote:
Scott I'm just finishing the PCB layout using Jim Wier's design. At
this stage I'm going to use a panel meter for the fuel gauge. Later I
might make another processor board for corrections since its not a
linear output. It will probably handle different fuels etc.
Greg
RV8
> Joe,
> What is the output of the VMS fuel probe? capacitance, frequency,
> voltage? It does have some kind of circuitry built into the end of it.
> I found an article by Jim Wier about building a capacitance fuel
> probe circuit which looks very doable.
> thanks for the info.
> Scott
> Joe Garner wrote:
>> <jgarner(at)dslextreme.com>
>> You can get the Princeton converter from Grand Rapids. Also I think
>> Blue Mt. makes one if you want to deal with them...
>> Several articles on the Internet for roll your own converters if you
>> search.
>> Im putting in a GRT EIS in place of an EPI800 which uses those same
>> probes.
>> HTH, Joe
>> Scott Derrick wrote:
>>> <scott(at)tnstaafl.net>
>>> Hi,
>>> I have Vision Microsystems capacitance fuel probes installed in my
>>> Velocity. I would like to use them with Dynon's EMS which requires a
>>> 0-5 volt output from the fuel probes. I don't know if the Vision
>>> probes
>>> output frequency, capacitance or voltage. Dynon didn't seem to know
>>> either.
>>> Vision is going through extreme changes since bought by JPI, tech
>>> support is nil, I've been waiting for a new Vision VM1000C since last
>>> august and have given up waiting.
>>> Any help in using these VMS fuel probes with the Dynon unit would be
>>> greatly appreciated. The probes worked fine for 450 hours with a
>>> VM1000
>>> unit,
>>> I have heard that Princeton Electronics made capacitance fuel probe
>>> converters but teh only number I have for them( 616-281-5193) is
>>> disconnected.
>>> thanks,
>>> Scott
> I would rather be exposed to the inconveniences attending too much
> liberty than to those attending too small a degree of it.
> Thomas Jefferson to Archibald Stuart, 1791. ME 8:276
The only security of all is in a free press. The force of public opinion cannot be resisted when permitted freely to be expressed. The agitation it produces must be submitted to. It is necessary, to keep the waters pure.
Thomas Jefferson to Lafayette, 1823. ME 15:491
greg(at)itmack.com Guest
Posted: Sun Apr 08, 2007 10:02 pm Post subject: VMS capacitance fuel probes used with Dynon EMS? |
Neither, Vans sells a kit that fits into their fuel tanks. If I new they
were this much trouble before hand I would have gone the old fashion route.
Greg
Greg,
Scott
Greg wrote:
> Scott I'm just finishing the PCB layout using Jim Wier's design. At this
> stage I'm going to use a panel meter for the fuel gauge. Later I might
> make another processor board for corrections since its not a linear
> Greg
> RV8
>> Joe,
>> I found an article by Jim Wier about building a capacitance fuel probe
>> Scott
>>> search.
>>> probes.
>>> HTH, Joe
>>>> Hi,
>>>> probes
>>>> either.
>>>> VM1000
>>>> unit,
>>>> disconnected.
>>>> thanks,
>>>> Scott
waters pure.
