scrimm
Joined: 09 Jan 2006 Posts: 81 Location: Gilbert, SC SC99
Posted: Tue Apr 03, 2007 4:50 pm Post subject: Rotax Generator |
Flight,
I need some direction (lots) on how to troubleshoot/test my Rotax generator and regulator to determine the reason why I have no power other than battery power.
Steve Crimm
N42AH
Still For Sale
www.stephenscott.com/Europa
_________________ Steve Crimm
N42AH |
ward.t(at)xtra.co.nz Guest
Posted: Tue Apr 03, 2007 5:20 pm Post subject: Rotax Generator |
Steve,
I had that problem.
Thought it was the regulator and had it tested ..no. It turned out to be the connecting DIN plug to the regulator was not sufficiently home and one of the female/male connections within the plug was not connecting probably. Dismantle the plug and clean. Check each connection is positively connecting and alter if necessary the female connector to make a positive connection.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Ph +64 3 3515166
Mobile 021 0640221
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
raimo.toivio(at)rwm.fi Guest
Posted: Wed Apr 04, 2007 12:11 am Post subject: Rotax Generator |
Steve
I had same trouble; no alt pwr at all
during first engine run upp.
Reason: those yellow wires from the
alternator to the regulator G-connectors
were not fully inserted /locked. Very simple!
They are quite easy to leave unconnected!
After fix I get more than enough power.
Hope that helps, Raimo
Raimo M W Toivio
OH-XRT Europa XS Mono #417, completed, taxi tests
OH-CVK C172 Skyhawk, under reinterioring in the Polar Circle
OH-BLL Beechcraft C45, w radial engines, grounded but lights on
37500 Lempaala
Finland
tel + 358 3 3753 777
fax + 358 3 3753 100
gsm + 358 40 590 1450
raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)
www.rwm.fi
rehn(at)rockisland.com Guest
Posted: Wed Apr 04, 2007 9:46 am Post subject: Rotax Generator |
Hi Steve
Can you describe what happened before failure, any work done, did charging go down gradually or instantly?
Jerry
