Another Build Table
BobTezyk
PostPosted: Tue Apr 03, 2007 8:48 pm    Post subject: Another Build Table Reply with quote
Good day all,
Here are pictures of my finished table less wood top and paint. It is made out of 1.5 in steel tube and turned out level, flat and true. I finally settled on a leg socket arrangement made up of 1.5 in square tube 4 in long with two 6 in long 1.5 in angle iron welded to it.
The sockets are slightly tapered to account slight misalignments of the top and bottom socket. To accomplish this, I built a shim out of a piece of scrap square tube and welded one spot on each side. This was placed in the top of the socket during welding and knocked out upon completion. The taper allows for the slight misallignment of the top and bottom sockets and for the tubes to slide in and out easily. I can change the height of the table by simply cutting new verticals. The minimum height for the table is 16 in for fuselage work.
One of my neighbors pointed out that I could remove the top and build arms for the base that fit the sockets to create a rotisserie for painting. Another neighbor suggested that I get 6 more nuts to lock the jack screws in place so they do not creep.
Yes, it is overkill but it sure was fun to build. It is an alternative for those who do not find working with wood fun. The project was something of a Tom Sawyer adventure. Two of my neighbors learned how to wire weld on it. That is why many of the welds are sloppy.
Closeup of the castor and Jackstand
 Filesize:  1.29 MB
 Viewed:  439 Time(s)
A closeup of the sockets, verticals, Jackstands and wheels. The jacks are for leveling and getting the wheels off the ground.
 Filesize:  711.79 KB
 Viewed:  428 Time(s)
The assembled build table. The jackstands are 1 in all-thread.
 Filesize:  1.47 MB
 Viewed:  519 Time(s)
This is the top, upside down, showing the upper sockets.
 Filesize:  1.32 MB
 Viewed:  450 Time(s)
This is the base with the verticals for a 36 in height
 Filesize:  1.45 MB
 Viewed:  446 Time(s)
View user's profile Send private message Send e-mail Yahoo Messenger
TxDave
PostPosted: Tue Apr 03, 2007 9:43 pm    Post subject: Re: Another Build Table Reply with quote
Wow! That is one substantial table, Bob. You could probably build a tank on it. If you haven't decided on a top yet consider 3/4" MDF. It makes for a very flat, smooth surface and is great when you need to drill and cleco parts directly to the table.
Just my humble opinion.
Dave Clay
Temple, TX
BobTezyk
PostPosted: Tue Apr 03, 2007 10:10 pm    Post subject: Re: Another Build Table Reply with quote
Thanks Dave,
I have 2 sheets of 3/4" B-C plywood to go on top already but that is a good thought. I will do that when it comes time to re-surface.
crvsecretary
PostPosted: Wed Apr 04, 2007 7:02 am    Post subject: Another Build Table Reply with quote
Hello Bob:
That is quite a work table !!! I don't think I've ever seen anything quite so hefty and stout.....
....oh wait !! I think I see the prototype of your table in the bottom of pic here...
(scroll down.....)
Just Kidding !!!!
That's a great looking table frame !!!! Good work !!!
Tracy Smith
Naugatuck, CT
Definitely Do Not Archive !!!!
In a message dated 4/3/2007 11:50:33 PM Eastern Standard Time, bob(at)eaglesnestestates.org writes:
--> Zenith-List message posted by: "BobTezyk" <bob(at)eaglesnestestates.org>
Good day all,
See what's free at AOL.com.
Zenith 601XL N458XL (reserved)
Naugatuck, CT
Tail Complete; working on wings
BobTezyk
PostPosted: Wed Apr 04, 2007 7:40 am    Post subject: Re: Another Build Table Reply with quote
Tracy,
Your right! I modified the blueprints from a Liberty Ship!
I knew I was going to take a ribbing for the overkill factor but that's OK. I'm tough. I can take it. I'll just sit in the corner chewing nails and spitting out battleships.
burbby
PostPosted: Wed Apr 04, 2007 2:40 pm    Post subject: Another Build Table Reply with quote
That should be strong enough. That is the way I like to do things also. Good job!!
BobTezyk <bob(at)eaglesnestestates.org> wrote: [quote]--> Zenith-List message posted by: "BobTezyk"
Good day all,
Bob Tezyk
N78QT - 601XL QB/ Jab3300
Started on elevator
Read this topic online It's here! Your new message!
Get [url=http://us.rd.yahoo.com/evt=49938/*http://tools.search.yahoo.com/toolbar/features/mail/] new email alerts[/url] with the free [url= http://us.rd.yahoo.com/evt=49938/*http://tools.search.yahoo.com/toolbar/features/mail/]Yahoo! Toolbar.[/url] [quote][b]
