dougsnash(at)yahoo.com Guest
Posted: Mon Apr 02, 2007 7:02 pm Post subject: SPAL linear actuator from Surplus Center |
Has anyone purchased one of the linear actuators
discussed on this list a couple of months ago from
Surplus Center? I ordered the 2" SPAL actuator (and
mount bracket) for use on my CH-701 and it arrived
today. Looks like a well built unit. Much better
than the plastic one I already had.
I am wondering if anyone has any installation pictures
or information on how to mount an electric actuator to
the plane for the flapperons. So far the only way I
can see to mount it is to the gear channel. This will
mean that the actuator will be extended when the
flapperons are retracted. Not ideal but with the
actuator being metal, that shouldn't be a problem.
I'm thinking there will have to be some stiffening
done to the top of the channel as well since it is
only 032.
A looked on the SPAL website tonight and checked the
wiring and specs for the actuator and found the have a
push button controller. It will give me three presets
with push button selection. Also according to the
instructions it is possible to adjust to settings in
between the presets by pressing 2/3 to extend and 1/2
to retract.
All told this should cost me about $150.00 with
shipping. Not too bad of a deal if it works like I
figure it will.
Doug MacDonald
CH-701 Scratch builder
NW Ontario, Canada
Fuse on the gear and working on the controls
Finding fabulous fares is fun.
Let Yahoo! FareChase search your favorite travel sites to find flight and hotel bargains.
http://farechase.yahoo.com/promo-generic-14795097
NYTerminat(at)aol.com Guest
Posted: Mon Apr 02, 2007 7:30 pm Post subject: SPAL linear actuator from Surplus Center |
Doug,
This is how I did mine
Bob Spudis
N701ZX/912S
See what's free at AOL.com.
556.67 KB |
781 Time(s) |
Kemter
Posted: Mon Apr 02, 2007 8:45 pm Post subject: Re: SPAL linear actuator from Surplus Center |
Check out Larry Martin's Skyhawg page:
http://www.skyhawg.com/electricflaps.html
Jim K.
701 construction on hold while deployed to Afghanistan
dbortol
Posted: Tue Apr 03, 2007 8:42 am Post subject: SPAL linear actuator from Surplus Center |
I bought the 4" actuator to use on my XL, but I decided against buying the controller. If any of the wires to the potentiometer in the actuator go open for any reason, the feedback voltage will be wrong and the controller will perceive an error between the commanded position and the actuator's current position. Unless the controller is specifically designed for this situation, it will attempt to eliminate the position error and drive the actuator to either the fully retracted or fully extended position. Maybe someone on the list who has the controller would like to test it and find out what it will do. I haven't tried one to verify my speculation. For my plane I decided that a simpler toggle switch will do the job, doesn't have this potential failure mode, and will fit on the control stick if I want to mount it there.
If you'd like an indicator for the flap position, you can wire the feedback pot to a Ray Allen indicator, or to a spare analog input on an engine monitor. I know that the Dynon engine monitor can be configured for a 'flaps' bar graph display. Others probably can too.
Dino Bortolin
La Salle, Ontario
On 4/2/07, MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)> wrote: [quote]--> Zenith-List message posted by: MacDonald Doug < dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)>
... snip ...
to retract.
figure it will.
Doug MacDonald
NW Ontario, Canada
Posted: Tue Apr 03, 2007 9:39 am Post subject: SPAL linear actuator from Surplus Center |
Another solution to the position problem would be to
install a switch in the power output to the motor that
would be used as a system enable. That way if the
controller did get scrambled, it would be unable to
output to the motor. Simply flip the switch on as
part of your downwind check.
Very good point Dino
Doug MacDonald
--- Dino Bortolin <dbortol(at)gmail.com> wrote:
| Quote: | I bought the 4" actuator to use on my XL, but I
input on an engine
configured for a
Dino Bortolin
La Salle, Ontario
Be a PS3 game guru.
Get your game face on with the latest PS3 news and previews at Yahoo! Games.
http://videogames.yahoo.com/platform?platform=120121
dbortol
Posted: Tue Apr 03, 2007 12:09 pm Post subject: SPAL linear actuator from Surplus Center |
You could do that, and if you catch a runaway in time, you can stop if from going any further. But you wouldn't be able to bring it back, unless you put in another switch to override the controller. At which point, I think it has turned the elegantly simple into the overly complex. But, that's the beauty of homebuilts - everyone is free to make it any way that suits them. I still like a DPDT toggle switch...
Dino Bortolin
On 4/3/07, MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)> wrote:[quote] --> Zenith-List message posted by: MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)>
Doug MacDonald
| Quote: | in the actuator go open
| Quote: | position. Maybe someone on the
| Quote: | If you'd like an indicator for the flap position,
input on an engine
configured for a
Dino Bortolin
La Salle, Ontario
Be a PS3 game guru.
macstar(at)raider.co.nz Guest
Posted: Wed Apr 04, 2007 12:17 am Post subject: SPAL linear actuator from Surplus Center |
Anyone got the URL for the surplus center?
Ian McClelland
601XL
Wing construction underway.
Posted: Wed Apr 04, 2007 3:00 am Post subject: SPAL linear actuator from Surplus Center |
Again, good points Dino. I'll have to play with the
controller once it arrives and make sure I'm not going
to induce a safety issue.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario , Canada
do no archive
| Quote: | You could do that, and if you catch a runaway in
Dino Bortolin
On 4/3/07, MacDonald Doug <dougsnash(at)yahoo.com>
to
that
to
> Doug MacDonald
TV dinner still cooling?
Check out "Tonight's Picks" on Yahoo! TV.
http://tv.yahoo.com/
Posted: Wed Apr 04, 2007 3:05 am Post subject: SPAL linear actuator from Surplus Center |
http://www.surpluscenter.com
Doug MacDonald
This should be committed to the archive
--- Ian McClelland <macstar(at)raider.co.nz> wrote:
Ian McClelland
601XL
secatur
Posted: Sat Apr 07, 2007 6:21 pm Post subject: Re: SPAL linear actuator from Surplus Center |
Hi Doug,
I purchased one some time ago and it's very good ! I mounted on two bits of .080 l back to back. There is enough clearance to miss the gear in the channel if you're careful.
Controls are really simple to use and adjust so I mounted the 3 button controller on a small bracket below the dash. I may change it later to just 2 positions on the stick , Wait and see.
Steve in Perth, Aust (fmrly from Montreal lol)
Fus on wheels /Tail done/engine in / Just wings & details to do but they'll have to wait 'til after I ship to NZ (where we're moving, again!)
172.25 KB |
787 Time(s) |
