n616tb(at)btsapps.com Guest
Posted: Sun Apr 01, 2007 3:13 pm Post subject: Noise on runup |
I would be looking for marks on the cowl or back of spinner. If need be one could shoot some light primer around suspect areas and then recheck for scuffing. You didn’t mention if this was a 6 or 6A, or maybe you do by omitting the (A). The comment here is be cautious with doing maximum RPM static run-ups as I have heard it can nose over.
Just ideas
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of FRANCIS MALCZYNSKI
Sent: Sunday, April 01, 2007 5:08 PM
To: RV-List Digest Server
Subject: Noise on runup
I have a friend who has comleted his RV6 and is ready to fly. However, when he does a static runup to check maximum RPM, he gets a rythmic noise that sounded to be like a resonant vibration of the engine hitting the inside of the cowl. The noise starts at about 2000 RPM. It is very loud and cannot be mistaken. Other people have heard it and described it as a whaa, whaa, whaa (can you aurilize this?) but again very loud. Any idea whats going on. The engine is a rebuilt 0320, 160hp, fuel injected running a 69 x 72 Performance Propeller. Could it be valve float?
Any and all facts or thories would be appreciated.
Fran Malczynski
RV6 - N594EF
Olcott, NY
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
Vanremog(at)aol.com Guest
Posted: Sun Apr 01, 2007 4:01 pm Post subject: Noise on runup |
In a message dated 4/1/2007 3:10:52 P.M. Pacific Daylight Time, airfran(at)verizon.net writes:
| Quote: | | I have a friend who has completed his RV6 and is ready to fly. However, when he does a static runup to check maximum RPM, he gets a rhythmic noise that sounded to be like a resonant vibration of the engine hitting the inside of the cowl. |
Alternator, exhaust pipe or airbox hitting against cowling?
GV (RV-6A N1GV O-360-A1A, C/S, Flying 840hrs, Silicon Valley, CA)
See what's free at AOL.com.
George McNutt
Posted: Sun Apr 01, 2007 4:23 pm Post subject: Noise on runup |
Hi Fran
Try a short run up with cowlings off to eliminate engine hitting cowling
(don't fry the cylinder)s.
How is the alignment of the alternator belt pulleys??
George in Langley BC
FRANCIS MALCZYNSKI wrote:
| Quote: | I have a friend who has comleted his RV6 and is ready to fly. However,
be valve float?
Fran Malczynski
RV6 - N594EF
Olcott, NY
Posted: Sun Apr 01, 2007 4:31 pm Post subject: Noise on runup |
Fran Malczynski
RV6 - N594EF
Olcott, NY
From an old time troubleshooter: Easiest first. Manually flex the prop
to be sure it doesn't have loose laminations. Check to be sure the
blades are tracked properly. (Did he check static balance?) Next, remove
the cowl & look for rub-points. Then do another runup to see if the
noise is gone without the cowl in place.
Not trying to offend, but he does have oil pressure, right? (It's
happened to others...)
Charlie
Hopperdhh(at)aol.com Guest
Posted: Sun Apr 01, 2007 4:36 pm Post subject: Noise on runup |
My advice in addition to that already posted is to be absolutely sure that the engine is not starving for fuel before flying. I don't think that is the case, but just be sure.
Full throttle runups are worse for vibrations than flying. If something is hitting you should be able to find it. The front of the engine moves around more than the rear. Do you have at least 3/8 inch clearance everywhere?
Dan Hopper
RV-7A
rv8a2001(at)yahoo.com Guest
Posted: Sun Apr 01, 2007 6:20 pm Post subject: Noise on runup |
There is a RV-6 at KSEE in San Diego that does the same thing. I think it also has the 320 and a fixed pitch but dont know which one. It is parked way on the otherside of the airport so I dont know what hanger its in. Every time that plane takes off people just shake there head saying there must be something wrong with it. Its been flying for 3 years this way that I know of.
Scott Bilinski
RV-8a
Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center. [quote][b]
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Sun Apr 01, 2007 6:30 pm Post subject: Noise on runup |
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
John.Morrissey(at)csiro.a Guest
Posted: Sun Apr 01, 2007 6:40 pm Post subject: Noise on runup |
Hi All,
This often has something to do with the length of the exhaust stack and how far it is away from the floor. As each beat from the exhaust leave the end of the pipe it expands rapidly and sometimes causes a resonant vibration in the floor.
Things to try:
- Add extensions to the tail pipe
- Glue some carpet on the floor
- Add a couple of flat AL strips across the floor
All of these could change the resonant frequency of the vibration in the area in question.
Good lick
John Morrissey
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of scott bilinski
Sent: Monday, 2 April 2007 12:19 PM
To: rv-list(at)matronics.com
Subject: Re: Noise on runup
Scott Bilinski
RV-8a
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center. | Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sun Apr 01, 2007 9:52 pm Post subject: Noise on runup |
In a message dated 04/01/2007 9:31:47 PM Central Daylight Time, jorear(at)new.rr.com writes:
| Quote: | | Any and all facts or thories would be appreciated. |
Vibration of oil-canning bottom skins or rudder? Might get someone to CAREFULLY look under the plane from behind the wing and press on suspect panels. Is noise accompanied by vibration sensed in seat or stick? Just a guess...
Mark - do not archive
_________________ From The PossumWorks... |
rembree(at)sympatico.ca Guest
Posted: Mon Apr 02, 2007 2:38 am Post subject: Noise on runup |
I had a resonant vibration that would occur at low power settings in flight. The baffle seal on one side was a bit too short and would flip inside out. I extended the baffle seal and the problem went away.
Roger Embree
[quote] I have a friend who has comleted his RV6 and is ready to fly. However, when he does a static runup to check maximum RPM, he gets a rythmic noise that sounded to be like a resonant vibration of the engine hitting the inside of the cowl.
[/b]
