norton(at)optonline.net Guest
Posted: Mon Apr 02, 2007 8:35 am Post subject: building a shed... |
Tom, Building the shed from scratch is much more economical than
building the shed from kits. The material list also helps you to buy
the materials as you need them, or to take advantage of any sales or
discounts on stuff you will need later. (Whenever you are in Home Depot
ask someone in the lumber department what's on the "cull cart" . As to
building a higher roof, think in terms of putting the entire structure
on a 2 foot or so base - such as laying two courses of cement block
underneath the outside wall. Then the entire structure will be 16"
higher using 8" blocks. The only adjustment would be the door will have
to lowered.
