Trim Tab Cable Anchor Bracket
jdalton77(at)comcast.net
PostPosted: Sat Feb 04, 2006 3:33 pm    Post subject: Trim Tab Cable Anchor Bracket Reply with quote
Zack,
Is Dave still making these replacement parts? and how can I order a set for my project?
I saw you referenced a web site in one message.  Does he have one?
Jeff
Closing up VS and Rudder
zackrv8
PostPosted: Sat Feb 04, 2006 7:51 pm    Post subject: Re: Trim Tab Cable Anchor Bracket Reply with quote
Jeff and fellow RV10 builders. Yes, Dave is still making these parts. If fact, he did a few more (see photos below). Dave is trying to put together an "RV10 Tail Kit". This kit will have many of the harder to make parts such as brackets, spacers and such. As I work on my tail kit, I ask Dave to make a part. He programs it on Solid Works and goes to town on the CNC.
Dave is hoping to put the following items in this RV10 Tail Kit Supplement....
Horizontal Stab Attach Brackets (hard to make for the builder so Dave
did it on the CNC with all holes predrilled! This is one bracket that
must be done right because it holds the front spar of the HS Stab to
the fuselage.)
Trim Cable Attach Bracket. The supplied Vans part is a cheap looking
part and binds the trim cable on my plane. Dave has a CNC billet
one that is 3 times stronger with the proper angle.
Pre cut foam blocks. Dave did mine on the CNC and they fit perfect!
CNC milled static air ports. See photo.
CNC cut brackets for the trim motor bracket and cables.
More to come. Call Dave at 302-437-6087. He can answer all questions on parts and prices.
Zack
#40512 ( tail cone riveting tomorrow! Wings ship next Monday!)
[quote="jdalton77(at)comcast.net"]Zack,
Is Dave still making these replacement parts? and how can I order a set for my project??
I saw you referenced a web site in one message.? Does he have one?
Jeff
 Filesize:  42.37 KB
 Viewed:  952 Time(s)
 Filesize:  38.58 KB
 Viewed:  989 Time(s)
 Filesize:  43.35 KB
 Viewed:  978 Time(s)
 Filesize:  37.93 KB
 Viewed:  979 Time(s)
 Filesize:  58.31 KB
 Viewed:  993 Time(s)
 Filesize:  40.83 KB
 Viewed:  955 Time(s)
 Filesize:  48.41 KB
 Viewed:  963 Time(s)
 Filesize:  41.33 KB
 Viewed:  959 Time(s)
 Filesize:  37.12 KB
 Viewed:  959 Time(s)
RV8 #80125
RV10 # 40512
pdwalter(at)bigpond.net.a
PostPosted: Sun Feb 05, 2006 3:38 am    Post subject: Trim Tab Cable Anchor Bracket Reply with quote
What would be the all up cost for all of these items mentioned ?
Paul Walter
Jon Reining
PostPosted: Mon Feb 06, 2006 5:10 pm    Post subject: Re: Trim Tab Cable Anchor Bracket Reply with quote
He has great customer service too. My anchor brackets showed up a couple weeks ago all beaten up. It looked like they got caught in UPS' conveyor/sorter system and then run over by a truck.
I called Dave, and he volunteered to send me a new pair free of charge. Today on my doorstep: a beautiful pair of anchor brackets.
Thanks Dave!
Jon Reining
Albany, CA
#40514
elevators
