swayze(at)europa.com Guest
Posted: Thu Mar 29, 2007 2:10 am Post subject: Left Elevator - rivets don't fit |
Hi Everybody,
I'm working on the left elevator for my RV-7A, and I ran into a
frustrating problem with some of the blind rivets required. There are
4 blind rivets on the top and 4 on the bottom of the skin, that hold
the skin to the outboard end of the E-606PP Trim Spar. This is the
aft spar on the elevator that carries the trim tab, and these are the
rivets forward and to the left of the little tabs that you bend over
on the skin surfaces. The rivets called for are MK-319-BS blind
rivets. They have brass-colored shafts. I tried every one of the
rivets included with my empennage kit, and none of them will fit in a
#40 dimpled hole. I tried a #30 hole in a piece of scrap, and it's
way too big. Nothing about this is mentioned on the drawings or in
the plans. All the other holes in this part are #40, and the standard
AN326AD3-3.5 rivets fit just fine. Am I missing something? Did I get
a bum batch of pop rivets? Or do I drill out the holes a little bit
bigger? If so, what size? I'm wondering if anyone else ran into this. Thanks.
Bruce Swayze
RV-7A Empennage
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Thu Mar 29, 2007 3:55 am Post subject: Left Elevator - rivets don't fit |
Bruce;
Most pulled or blind rivets by their very nature are not as strong as solid rivets. To give them all the help they can get blind rivets should be inserted into a prepared holes that are very close to their diameter.
You ran into a typical situation that is easily resolved by investing in a cheap digital micrometer and a drill index chart. Enclosed is a copy of my favorite chart. I find I refer to both tools often for one task or another. If you measured the MK-319-BS, you would find it mics out at approximately .110-.111 in diameter. The dimpling operation opened up the material just a bit. Therefore, the correct drill bit to prepare a hole to accept a MK-319-BS is 7/64."
http://img376.imageshack.us/img376/5454/img153pr3.jpg
Rick Galati RV-6A "Darla!"
RV-8 Fuselage
86.13 KB |
448 Time(s) |
vhimsl(at)adelphia.net Guest
Posted: Thu Mar 29, 2007 6:34 am Post subject: Left Elevator - rivets don't fit |
I use 7/64, #33 or #34 (mostly #34). Start out small and progress to larger.
Skin thickness, dimpling, etc. make a difference. The #40(many prefer a #41)
and #30 are for standard rivets. The blind 'Pop' rivets are thicker.
You will find a drill bit gauge (flat plate with holes in it) for numbered
bits to be most useful. With the gauge you can put the pop rivet (screws,
pins, etc.) in each of the holes to find the right bit. Saves a lot of time!
It is even quicker than walking the extra five feet to my builders log to
search for the page where I wrote down the drill bit size the last time I
needed it.
Also get a chart that shows all the drill bits, both numbered and fractional
together so you understand relationship say between a 1/8th and a #30.
7/64" = .1094
#35 = .1100
#34 = .1110
#33 = .1130
#32 = .1160
#31 = .1200
1/8" = .1250
#30 = .1285
#29 = .1360
You might want to pick up drill bit #'s 11, 12, 19, 21, 27, 29, 'D', 33, 34,
35, 36, and 37. They're for bolts, screws, other...Can't remember all the
reasons, but I have them and they look well used.
When I first started, pop rivets were to be avoided at all cost. Now, pop
rivets are my friends. Lost track of dings caused trying to avoid using
them.
Vince H.
RV8 - VSB finish
Moscow, ID
truflite(at)yahoo.com Guest
Posted: Thu Mar 29, 2007 6:53 am Post subject: Left Elevator - rivets don't fit |
My guess is that you have the wrong rivet. I just
looked at my elevator and found an aluminum rivet and
a steel pin. The rivet I ended using there is a
MK319BS.
Dave
--- Bruce Swayze <swayze(at)europa.com> wrote:
Hi Everybody,
ran into a
required. There are
skin, that hold
Spar. This is the
and these are the
that you bend over
MK-319-BS blind
every one of the
them will fit in a
scrap, and it's
drawings or in
and the standard
holes a little bit
Bruce Swayze
RV-7A Empennage
browse
Subscriptions page,
FAQ,
Web Forums!
Be a PS3 game guru.
Get your game face on with the latest PS3 news and previews at Yahoo! Games.
http://videogames.yahoo.com/platform?platform=120121
matronics(at)cencula.com Guest
Posted: Thu Mar 29, 2007 7:30 pm Post subject: Left Elevator - rivets don't fit |
Here's a picture of the correct rivet to use.:
http://www.our7a.com/20061007.html
Others are correct, the holes need drilled out to 7/64.
Mike
On Thursday March 29 2007 06:10 am, Bruce Swayze wrote:
Hi Everybody,
Thanks.
Bruce Swayze
RV-7A Empennage
