Digitrak Op Manual?
Jerry Cochran
PostPosted: Wed Mar 28, 2007 5:34 pm    Post subject: Digitrak Op Manual? Reply with quote
Listers,
Does anyone happen to have a current PDF of Trutrak's "Digitrak Operating Manual"? There website must be down, I've gotten the "404 error" message on two diff computers now in trying to get a download.
I have the older manual, but need the later one that covers the Garmin 296 setup.
If you have it, could you email same to me? Much appreciated. Do not archive.
Jerry Cochran
See what's free at AOL.com.
dale1rv6(at)comcast.net
PostPosted: Wed Mar 28, 2007 5:57 pm    Post subject: Digitrak Op Manual? Reply with quote
Hi Jerry,
I just found it, link below. PDF attached
http://www.trutrakflightsystems.com/documents/DigiflightIIOperatingManual.pdf
I used Google to find Trutrak, clicked on link, got redirected to a new site name:
Hope this helps,
Dale
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jerry2DT(at)aol.com
Sent: Wednesday, March 28, 2007 9:34 PM
To: rv-list(at)matronics.com
Subject: Digitrak Op Manual?
Listers,
Jerry Cochran
 Filename:  DigiflightIIOperatingManual.pdf
 Filesize:  140.93 KB
 Downloaded:  674 Time(s)
retasker(at)optonline.net
PostPosted: Wed Mar 28, 2007 8:16 pm    Post subject: Digitrak Op Manual? Reply with quote
I think that this is what you want:
http://www.trutrakflightsystems.com/documents/handheldgpsconfig.pdf
Or you can go to:
to browse all the documents in a FTP type format.
I believe that the reason you may not be able to get to them directly is that they have converted the entire site to use Flash - the main page tells you that, but other pages you may have saved or gotten from a Google search give a 404 error because they do not exist anymore. I HATE that as I do not have or want Flash installed (just more software to go bad or screw up my system).
Trutrak management, if you are listening - "GET RID OF THE FLASH ONLY WEB SITE!!!!"
Dick Tasker
Jerry2DT(at)aol.com (Jerry2DT(at)aol.com) wrote:
Listers,
Jerry Cochran
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Jerry Cochran
PostPosted: Thu Mar 29, 2007 12:47 pm    Post subject: Digitrak Op Manual? Reply with quote
Thanks Dale & Richard,
Yes it was the "Flash" deal as one of you mentioned. Thanks mucho, PDF received.
Jerry C.
