Posted: Wed Mar 28, 2007 10:18 am Post subject: New 912ULS Oil Fittings |
Hi Gang:
Need some help with the new, push on type, oil line fittings used on
the 912ULS oil tank and engine.
What is the prescribed procedure for installation and security?
Also, prescribed procedure for removal.
I found some info last night on the internet. From what I could make
out, it is a simple push on fit with no securing hose clamp.
_________________ John Hauck
Titus, Alabama |
JetPilot
Posted: Wed Mar 28, 2007 1:50 pm Post subject: Re: New 912ULS Oil Fittings |
Here is a pictre of mine.
511.09 KB |
527 Time(s) |
Kolb MK-III Xtra, 912-S |
Roger Lee
Posted: Wed Mar 28, 2007 2:36 pm Post subject: Re: New 912ULS Oil Fittings |
Hi John,
With the correct push-on fittings and correct hose (special hose for push on only) you are technically right that they are push on only, but Rotax would like those backed up with a clamp. If they were enclosed in a cowling then they would like fire sleveing , too. But I know your plane is an open engine mounting.
I can only guess that they want a clamp because we don't drive on the ground?
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Wed Mar 28, 2007 2:42 pm Post subject: New 912ULS Oil Fittings |
Thanks, Mike B:
But..............your fittings are the old style, like I had on my
last engine.
Titus, Alabama |
Posted: Wed Mar 28, 2007 2:52 pm Post subject: New 912ULS Oil Fittings |
| Roger Lee
Hi Roger:
No problem with the push on fitting. The 912 series engines are
operating on a vacuum for the feed line from the oil tank, and 3 to 5
psi on the return line to the tank.
I may use a narrow SS hose clamp as backup, or a couple wraps of
safety wire, just to make an old man feel better.
Take care,
Titus, Alabama |
