Posted: Thu Mar 22, 2007 7:24 pm Post subject: Leading edge deformation |
To All,
About a month ago, someone posted a photo of their leading edge of the
wing. It appeared to have a significant amount of depression due to
on-coming air. That strikes me as a big no-no!!
Ok, here's the question. Since I haven't covered my wings yet, is
there a way to help overcome this situation? I have an idea or two, and I
want to run it past those who know something on the subject.
Idea #1 Run another line of 3/8" tubing 10" back from and parallel to
the leading edge (or whatever distance looks like it would do the most
good. (This certainly would keep the fabric from depressing as much)
Idea #2 Double up the fabric on the front upper 18". By adding an
extra layer along the most affected area, I would think this also would do
quite a bit of good.
I know neither of these methods would add more than a few ounces to the
weight of the plane, so I know weight isn't a really big issue. Is any of
this worthwhile, or am I just wasting my worries on a non-event?? (In
other words, was the photo taken of the leading edge deformation doing 110
mph???
Mike in SW Utah
Watch free concerts with Pink, Rod Stewart, Oasis and more. Visit MSN
Presents today.
http://music.msn.com/presents?icid=ncmsnpresentstagline&ocid=T002MSN03A07001
Posted: Thu Mar 22, 2007 7:33 pm Post subject: Leading edge deformation |
edge of the
| Mike in SW
Utah
Mike:
Where do you guys come up with these questions of procedures we have
been doing for years with great success.
If you cover and shrink the fabric correctly, you will not have a
problem with funky leading edge fabric. Those depressions of the
fabric serve a purpose. that is why Homer did not put a metal or wood
leading edge on the wing.
Mine has depressions and flies pretty good.
mkIII With depressed fabric
_________________ John Hauck
Titus, Alabama |
possums(at)bellsouth.net Guest
Posted: Thu Mar 22, 2007 7:59 pm Post subject: Leading edge deformation |
At 11:33 PM 3/22/2007, you wrote:
edge of the
no no !! ..we have discussed this several times before. Even if you put
metal on the leading edges back 6 or 7 inches, it doesn't make any difference.
I think Dennis has some info on that in the archives. Kind of like
the dimples on
a golf ball. Things that are smooth don't always fly better. Kind of like why
shark skin is "rough" like sand paper. Kind of like "Vortex Generators".
jcooley380(at)hughes.net Guest
Posted: Fri Mar 23, 2007 1:04 am Post subject: Leading edge deformation |
To All,
Hi Gang,
Mike: You can minimize the scalloping by using the right ironing technique
and the fabric will be very tight between the nose ribs. It's been a while
for me, but you basically iron between the nose ribs before ironing the rest
of the wing. Give Jim and Dondi Miller a call at Aircraft Tech Support for
detailed info(Polyfiber dealers). They are a great asset when it comes to
covering and painting.
Good luck.
Later,
John Cooley
7:44 AM
rowedenny(at)windstream.n Guest
Posted: Fri Mar 23, 2007 2:40 am Post subject: Leading edge deformation |
Also follow Jim and Dondi Millers instructions when shrinking the wing
fabric to minimize leading edge scalloping between the ribs.
If I recall correctly you iron the leading edge fabric first concentrating
between the ribs and false ribs.
D Rowe, Mk-3
Posted: Fri Mar 23, 2007 2:42 am Post subject: Leading edge deformation |
Whoops, I should have learned by now to read all my mail before replying,
well said John C, you beat me to the punch.
Denny Rowe
jindoguy(at)gmail.com Guest
Posted: Fri Mar 23, 2007 4:42 am Post subject: Leading edge deformation |
NACA did wind tunnel tests in the 30's to see if the shrinkage between ribs had any effect on the lift or drag of the wing. They found it was negligible.
Do your best work, per plans, and relax.
Rick
On 3/23/07, Denny Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:[quote] --> Kolb-List message posted by: "Denny Rowe" <rowedenny(at)windstream.net (rowedenny(at)windstream.net)>
Denny Rowe
MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Fri Mar 23, 2007 5:29 am Post subject: Leading edge deformation |
Funny you should ask Mike.
I just read somewhere, sorry don't know for sure where.
The depressions between ribs seem to have no effect on performance but a ridge does. Kolbs don't have that ridge. If you add a lateral piece of tubing you may do more harm than good.
If I can find the source I will pass it along.
Vic
912 UL Extra
Maine
_________________ MKIIIX040
912UL |
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Fri Mar 23, 2007 6:58 am Post subject: Re: Leading edge deformation |
Mike:
I think where you went astray is the assumption that the depression between ribs is due to "oncoming air". If this were true, it would be a no-no. The depressions are a natural result of shrinking the fabric over the Kolb wing. Take a good look at the on ground and in-flight pictures posted on this site and others and you will see that the depressions do not change from "oncoming-air". I did a quick search of my pictures and found these two shots that might help prove my point.
143.85 KB |
371 Time(s) |
182.71 KB |
379 Time(s) |
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Fri Mar 23, 2007 7:20 am Post subject: Re: Leading edge deformation |
Please do not do this. You will drastically change the airfoil characteristics, and almost certainly not for the better.
_________________ Scott
www.ill-EagleAviation.com
do not archive |
planecrazzzy Guest
Posted: Fri Mar 23, 2007 1:40 pm Post subject: Re: Leading edge deformation |
Was this the picture ???
Gotta Fly...
Mike & "Jaz" in MN
34.72 KB |
362 Time(s) |
Posted: Fri Mar 23, 2007 3:32 pm Post subject: Leading edge deformation |
To Mike and Jaz,
Wow!! Yes, that is the picture I was referring to. Boy, it sure
doesn't look near as bad as I remember. Plus, the shadowing excetuates the
depressions, making them look a little worse than they obviously are. (Which
aren't that bad after all.)
Thanks, Mike, for doing the research and helping me see that this
situation really isn't an issue, at all. Livin' and learnin'
...... Thanks for you guy's help! Mike in SW Utah
Do not archive.
Presents today.
