paul.folbrecht(at)veribox Guest
Posted: Fri Mar 23, 2007 8:25 pm Post subject: 9A VS parts list |
My tech counselor recommended I rebuild my VS. (Biggest problem was
I bucked rivets on the spar because I didn't have a squeezer that
could do 1/8" rivets.) Anyway, I called Van's to order the parts and
basically they have no concept of a "vertical stab" subkit - you need
to have the full parts list. Does anybody happen to have this handy
for a 9A??
tc1234c(at)roadrunner.com Guest
Posted: Sat Mar 24, 2007 2:57 am Post subject: 9A VS parts list |
Paul,
Section 4 of your construction manual is a complete parts index. Parts for
VS begins with VS and is on "PLAN PG #6". Unfortunately, several VS parts
are listed at end of the list with unknown PLAN PG #. Here are what I found:
VS-410PP-PC x 2
VS-411PP-PC x 2
VS-412PP-PC x 2
VS-803PP x 1
VS-808PP x 1
VS-901 x 1
VS-909 x 1
VS-702 x 1
VS-704 x 1
VS-705 x 1
VS-706 x 1
VS-707 x 1
Double check the above list against DWG 6 and see whether anything is
missing. There are various rivets used and they are not listed on the parts
list.
Ted
T.C. Chang
http://tc1234c.googlepages.com/
RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, Dual Mag, Sensenich FP
all electric, GRT dual DU H1, TT DigiFlight II VSGV, 125 Hobbs 3/8/2007
