luigit(at)freemail.it Guest
Posted: Tue Mar 20, 2007 12:25 am Post subject: Fiberglass fuselage |
On my Esqual, installing the radio system, an Icom- ICA 200, I wish to put the antenna inside the fusolage, behind the seat or inside the tail.
Are there any experience/suggestion to keep ? Length of coaxial cable, position, shield.....
Thank-you for any help.
Really appreciated, indeed.
Luigi, Rome, Italy
-- Uso la webmail Dada.net, l'email delle persone che contano e che si raccontano --
longg(at)pjm.com Guest
Posted: Tue Mar 20, 2007 5:54 am Post subject: Fiberglass fuselage |
Luigi,
I will do the same with two of the EI bipole antennas. The word is there is no affect from the fiberglass. Do not try the same with carbon fibre which will block the signal. In fact, I have now seen a number of aircraft with the antenna farm in the tail. I am building a Legacy FG which will include two comm, one gs and one marker beacon in the tail. That's the nice thing about fiberglass, you can always move it after testing if necessary.
N6030X(at)DaveMorris.com Guest
Posted: Tue Mar 20, 2007 6:40 am Post subject: Fiberglass fuselage |
If your tailcone has a diameter of around 31 inches, you can try the
Morris Com Loop antenna, which does not require a ground plane and is
a better antenna than the typical quarter wave
whip. www.DaveMorris.com/MorrisComLoop
Dave Morris
At 03:24 AM 3/20/2007, you wrote:
inside the tail.
Luigi, Rome, Italy
-- Uso la <http://it.email.dada.net/cgi-bin/login.chm>webmail
Earl_Schroeder(at)juno.co Guest
Posted: Tue Mar 20, 2007 2:49 pm Post subject: Fiberglass fuselage |
Hi Luigi,
In my Lancair [fiberglass not carbon] I have my Icom-200 connected to a
Jim Weir dipole made from 1/2 wide copper tape. Works great!
Ref URL: www.rst-engr.com/
Earl
luigit(at)freemail.it wrote:
tail.
Luigi, Rome, Italy
