rdhowey(at)telus.net Guest
Posted: Fri Mar 16, 2007 4:57 pm Post subject: DeltaHawk Engine |
I'm still working on the empennage of my 8 quick-build kit and am spending way too much time daydreaming, panel planning and lurking on the web. I know I should be out in the shop squeezing rivets and mangling lovely pieces of .020 but I have an important question for group I hope you can help me with.
Two days ago Dennis Webb from DeltsHawk Engines Inc (www.deltahawkengines.com) e-mailed me to offer a position in their projected delivery for 2008 and requesting a $5000 deposit. This will establish me in the line-up and I should receive my engine some time in 08,,,, hopefully I'll have completed the empennage by then and maybe even closed up the wings..hope hope...Actually the timing should work quite well for me given my pace
I have read as much about Deltahawk and their DH180A4 as I can find on the web and Kitplanes author Tim Kern ran a very complimentary article in the December 2006 issue. The engine appeals to me for any number of reasons, direct drive purpose-built aviation engine, fuel availability, low fuel burn, durability, you can read all the hype on their web site.
BUT......I need some advise and a devil's advocate or two
(1) what about firewall forward installation...engine mounts..cooling rads..cowl design..exhaust and muffler..fuel pumps, filters and return lines, and all those things I haven't even thought of
(2) company viability and the chance of me kissing my 5grand goodbye
If anybody has any thoughts on this we can start a string or you can e-mail me directly with your comments good or bad.....the more input the better.
My thoughts are I'll fly to Chicago and drive up to Racine to do the touchy-feely before I write the cheque ( check ), I retired from an airline job 1 Jan so do have some time available and the ticket won't cost much..
Thanks very much...
Ralph Howey
Delta B.C.
martin(at)gbonline.com Guest
Posted: Fri Mar 16, 2007 5:21 pm Post subject: DeltaHawk Engine |
Ralph,
I have been in business for over 45 years and anytime I see a request for a large downpayment from a relitivly new company for a $5000 downpayment for something that I will not need for l or 2 years, I become very suspicious. If their terms demand a large downpayment for something that you will not need for at least one or two years, I would suggest that you keep your money in the bank earning interest and hold off untill you are within 6 months of requiring an engine for your airplane.
Dick Martin
RV8 N233M
the fast one
khorton01(at)rogers.com Guest
Posted: Fri Mar 16, 2007 5:48 pm Post subject: DeltaHawk Engine |
On 16 Mar 2007, at 20:56, Ralph Howey wrote:
| Quote: | I'm still working on the empennage of my 8 quick-build kit and am
If you are still working on your empennage, you are a long way away
from needing an engine. If your build goes at the pace of many
builders, you may not need an engine for several years. The DeltaHawk
engine has zero service history at the moment. There will almost
certainly be changes made as a result of problems experienced in
service. If you take delivery of your engine too early, you won't
get the improvements that are made later.
Will your money be held in escrow, or is there a risk that the
company could go bankrupt and you lose it? If it later turns out
that the engine isn't nearly as good as it is currently claimed to
be, can you get your money back, or is this a non-refundable deposit?
Having to sort out engine mount, cowling, radiator mount, etc, etc
will add a lot of complication and cost to the project. This is OK
as long was you enjoy this sort of thing, and are in no rush to get
finished and have cash to burn. If you are hoping to get flying as
early as possible, or as cheaply as possible, stick with a Lycoming.
Personally, I would prefer to see a reasonable amount of good service
history before I committed to something as important and expensive as
an engine. Putting $5,000 down now only makes sense if you are
comfortable with the possibility of having that money be lost.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
n801bh(at)netzero.com Guest
Posted: Fri Mar 16, 2007 8:05 pm Post subject: DeltaHawk Engine |
Dennis emailed you asking for 5000.00 for an engine to maybe be delivered in two years. ?? I give it a 99.9% chance you will never see that engine or your money.. IMHO
Ben Haas
N801BH
www.haaspowerair.com
Thanks very much...
Ralph Howey
Delta B.C.
tronics.com
ronlee(at)pcisys.net Guest
Posted: Fri Mar 16, 2007 8:37 pm Post subject: DeltaHawk Engine |
Go hide your checkbook and credit card(s). Kevin was right on. Do you
want to do all the mods needed to make this work in a proven design like
RV plus Lycoming type engine?
Fuel availability? How many airports have diesel? How will you refuel
going cross-country?
Get this thought out of your mind for now and ask again in a year.
Even then I would not likely recommend this engine.
Ron Lee
This message was sent using Endymion MailMan.
http://www.endymion.com/products/mailman/
sbuc(at)hiwaay.net Guest
Posted: Sat Mar 17, 2007 3:29 am Post subject: DeltaHawk Engine |
ronlee(at)pcisys.net wrote:
Good advice.
| Quote: | Fuel availability? How many airports have diesel? How will you refuel
No problem here. The aviation diesels burn Jet-A which is one of the
main appeals of a diesel.
Sam Buchanan
seipel(at)seznam.cz Guest
Posted: Sat Mar 17, 2007 4:46 am Post subject: DeltaHawk Engine |
I followed Deltahawk for a long time, with the thought that I wanted to
put their 200HP inverted engine in my RV-10. After building for 4
years, during which Deltahawk continued to say there were "just about to
start delivering engines", I ordered a lycoming to avoid bringing my
project to a halt. I still watch their progress on their webpage.
I think that eventually they'll deliver engines, and that they'll be
good engines. They've made a lot of progress in the time I've been
watching them. However, this is going to be the big challenge for you:
Deltahawk is only interested in providing engines. If you buy an engine
from them, either someone else has to build the firewall forward for
you, or you've got to do it yourself. Don't underestimate the amount of
engineering that will go into the engine mount, oil system, cooling
system, etc.
The fact that they want a deposit for something they'll deliver in 2008
means that they're either assembling the engines extremely slow, or
they're going to use your money help to pay for the engines they
promised in 2007. As we've seen with Direct-2-Avionics, that puts your
deposit at serious risk if they run out of capital. My response would
be different if they were delivering engines like hotcakes; I paid
Barrett half the cost of my lycoming several months ago, but I'm
comfortable that he's going to send me an engine when he says he is.
PJ Seipel
RV-10 #40032
(www.deltahawkengines.com <http://www.deltahawkengines.com>) e-mailed
given my pace
their web site.
the better.
cost much..
Thanks very much...
Ralph Howey
Delta B.C.
gcomfo(at)tc3net.com Guest
Posted: Sat Mar 17, 2007 6:23 am Post subject: DeltaHawk Engine |
wdleonard(at)gmail.com Guest
Posted: Sat Mar 17, 2007 7:59 am Post subject: DeltaHawk Engine |
Hi Ralph,
You have read some good advise so far an I agree with most of it. A company that has been 1 year away from delivering engines for the last 5 years and is still not delivering engines does not deserve $5000 of your hard earned money. A good faith deposit is one thing, but you (as a builder) are not in the business of providing investment capitol. DH should take smaller deposits and use them to convince the bank that their engines will sell.
That being said, I sure hope they make it. Being a fan of alternate engine choices I followed DH for a couple of years but wanted to get started long before they were ready. I looked at their site last night for the first time in years and am very impressed. The engineering and flight data is new and particularly impressive. If I had to guess, $5000 put down now would eventually see an engine at your door.... but maybe not in 2008.
Anyway, I wanted to address your concerns about FF fabrication, having done it for my rotary RV-6. That stuff is not harder than the other systems you develop in building an RV. I spent about 2-3 months of my build time (couple half-day/week type thing) on the engine mount, and 2 more months on cooler placement and I keep changing the cowl. The nice thing for you with the DH is that the intake and exhaust manifolds are already done, same with the fuel, oil, injector, and electrical systems around the engine. Those were some of the hardest parts of my installation. Of course, I am still tinkering and making changes while the lyc guys are buzzing my house... but by 'next year' I should have it all worked out
David Leonard
Turbo Rotary RV-6 N4VY
My websites at:
http://members.aol.com/_ht_a/rotaryroster/index.html
http://members.aol.com/_ht_a/vp4skydoc/index.html
http://leonardiniraq.blogspot.com
On 3/16/07, Ralph Howey <rdhowey(at)telus.net (rdhowey(at)telus.net)> wrote: | Quote: | I'm still working on the empennage of my 8 quick-build kit and am spending way too much time daydreaming, panel planning and lurking on the web. I know I should be out in the shop squeezing rivets and mangling lovely pieces of .020 but I have an important question for group I hope you can help me with.
Two days ago Dennis Webb from DeltsHawk Engines Inc (www.deltahawkengines.com ) e-mailed me to offer a position in their projected delivery for 2008 and requesting a $5000 deposit. This will establish me in the line-up and I should receive my engine some time in 08,,,, hopefully I'll have completed the empennage by then and maybe even closed up the wings..hope hope...Actually the timing should work quite well for me given my pace
Thanks very much...
Ralph Howey
Delta B.C.
Posted: Sat Mar 17, 2007 12:18 pm Post subject: DeltaHawk Engine |
| Quote: | > Fuel availability? How many airports have diesel? How will you
refuel
| Quote: | > going cross-country?
Sam Buchanan
Thanks Sam. I did not know that. Of course there is no Jet A at my
airport.
Ron Lee
Do not
archive
seiders(at)bellsouth.net Guest
Posted: Sat Mar 17, 2007 2:52 pm Post subject: DeltaHawk Engine |
No way would I put $5000 down. Don't know why any firm needs a deposit before taking delivery on other than a special custom order.
Dick RV6A
Thanks very much...
Ralph Howey
Delta B.C.
deruiteraircraftservices( Guest
Posted: Sun Mar 18, 2007 12:51 am Post subject: DeltaHawk Engine |
Hi guys,
Apologies to butt in on this topic.
I must say I live across the Atlantic, we don't have as much freedom here to change what we want on our aeroplanes due to the need of some authoritive figures wanting to tell what you can or can't do.
I have been on this list for quite a few years now and have seen many 'new' engines come and go or be a major disappoinment, either by the lack of permance or their integration with the RV airframe. Think the Thielert Diesels, conversion cost some $20K over new Lyco price and cut in performance to save a $$ on fuel. Maybe their new offering is better?
Can some try to explain what is so attractive to an engine that has an unknown service history, unknown performance and to top all, is often more costlier when the full installation is completed?
I personally don't see much sense in for example the Superior engines, the difference with genuine Lycoming is very small and a full service record has still to be established. I know their parts are authorized to be used on cert Lycomings, but that's still different in my book to an entire engine built of those parts.
Part of this doubt may be caused by the way parts are sold and kept here in Europe, but seeing the RV is pretty much a travelling aeroplane, it make sense to me to stick to something 'standard' as Murphy says your aeroplane will only break away from base. What better than being able to walk straight to the nearest mechano and say: my Lyco has packed in , help please. The mechano will see something he familiar with, the engine gets fixed and you're on your way again.
If you already have reservations about putting down a deposit, what is it going to be when you actually need parts for your engine? I mean I can understand the factory's position by trying to generate a cashflow, but it doesn't look good if some of their machines break down or something alike. If they only sell production slots now, how long before they have time to do a couple of runs of spares?
I know this may not be the most optimistic approach to something like this, I have been running a repair shop specialising in repair of homebuilts, but the most frequent customers are those with alternative engines, composite designs etc.
cjensen(at)dts9000.com Guest
Posted: Sun Mar 18, 2007 4:34 am Post subject: DeltaHawk Engine |
RAS,
Your well reasoned and considered argument for stasis is logical, but logic and common sense is only a small part of the decision equation. Progress, improvements and advancements occur only because individuals, against all good logic and common sense decide they want to try the newest, greatest, fastest, shiniest, coolest. In making that decision we already know there are going to be a few "Affordable Turbines" in the lot, but that's the price of progress. Some are willing to risk their time, effort and money on the oft chance that the newest, latest and greatest is just that.
But for the willingness to try different things, we would all be driving American-built cars that were good for 50,000 mile (maybe) before they were a pile of junk (remember the '70s and '80s?). Now, American-built cars, after responding to foreign competition, are good for 100,000 before they need a tune-up. This came about simply because a large number of people said the status quo is not good enough. Progress comes in fits and start and is rarely a pretty process, but it never occurs unless people are willing to buck the system and take chances.
In the end, its probably a cultural thing. It's why in the U.S. we have many breakthroughs, and many abject failures...but always a subset of people willing to try the new and unknown.
Now, with that said, I would hesistate to put down a $5,000 deposit on an engine of an unknown level of development and uncertain future, unless I gave the money a proper going away party and with expectation that we are unlikely to meet up again in the future.
Chuck Jensen
Note: New Phone Extension
Posted: Sun Mar 18, 2007 5:14 am Post subject: DeltaHawk Engine |
Funny, you didn't mention a thing about the 3 Lycoming crankshaft recalls, the cranks that have killed 15 or more humans so far, and caused untold millions of lost revenue for the operators of those "certified" engines. The latest recall, actually they are now calling it an "early retirement" of cranks and the customer gets to eat most of the cost of their poor business practices. Granted the alternative engine market is not the best either but the true intent of the homebuilt / experimental plane avenue is to push the envelope and find better stuff. The very thing "certified" planes cannot do. IMHO
Ben Haas
N801BH
-- "RAS" <deruiteraircraftservices(at)btinternet.com> wrote:
Hi guys,
tronics.com
lors01(at)msn.com Guest
Posted: Sun Mar 18, 2007 8:14 am Post subject: DeltaHawk Engine |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> RAS, It's the Romance man!
I would not put down $5k on this thing either but that's a different matter. To some of us, there is an irresistible appeal to having something different under the cowl, especially if it offers some advantages. Just cruising along hearing that very alien sound from an engine installation of your own design adds a whole new dimension to flying for some of us.
Tracy Crook
Mazda 13B powered RV-4 1600+ hrs
Mazda 20B powered RV-8 (still waiting on Bluemountain EFIS1)
Posted: Sun Mar 18, 2007 10:47 pm Post subject: DeltaHawk Engine |
Ben,
The point I was trying to make that like for like purchase price does not give enough of a difference to really justify a lot of the experimentation with non Lycoming engines on RV's. The prices for the Lycomings through Van's make it very difficult for any company to be really competitive. I don't think that couple of thousand is truly enough. I know that with the Superior you can just bolt on when it comes to an RV, however you do loose the SB and AD warnings.
here in Europe Thielert has been marketing their Centurion Engine. Nice story aout the 15litre or so fuel burn, what it doesn't say though in the bold advertising print that you get a reduction of 300LBS or thereabout on your C172 or PA28. Now, in my book that's a hell of trade off. The engine conversion cost for said aircraft is around £45,000, read this pounds not dollars! Must a complain about the odd inconvenience of a SB or AD even if it does cost $2,000 to replace a crankshaft? Me thinks not.
With regards to the last 3 recalls re: crankshafts, there's not one engine hit by all three
You mention the millions of lost revenue, how much would have been lost if the superior engines would have been certified when they had the recall on cylinders? Last time I looked engines don't run equelly well without either a crank or the cylinders....
The human life is always and will always be a tragedy. Compliance with SB and AD is paramount to try and avoid loss of life. That's what they're there for, even though some think it's just a money spinner. However improper produced parts are a risk. Rather than complain about the cost and annoyance of compliance, carry them out and make sure those who died did not do so in vane.
Marcel
