dan(at)rvproject.com Guest
Posted: Sun Mar 18, 2007 4:51 pm Post subject: Z-bracket height (again) - Help! |
Check the aft flange bend angle on the fuel tank ribs. If it's not 90
degrees, then it pushes the baffle "aft" and causes the problem you're
seeing.
Also make sure the fuel tank ribs are well seated inside the tank skin.
That means all flanges on all tank ribs are square, and the "flats" around
the nose aren't causing "high spots" that prevent the nose of the rib from
seating all the way fwd.
)_( Dan
RV-7 N714D (1230 hours)
www.rvproject.com / www.weathermeister.com / www.weighmyplane.com
