mhcrowder
Posted: Mon Mar 19, 2007 3:35 pm Post subject: EGT Probes on J3300 and Sonex |
I'll be mounting the Jabiru 3300 on my Sonex in the next few weeks and wanted to see if anyone has any words of advise about where to mount the 6 EGT probes from and EIS. The Jabiru Manual states...
"Exhaust Gas Temperature (EGT) - Nominal 650 degrees C – 750 degrees C (1202 degrees F – 1382 degrees F) measured 100mm from the exhaust manifold flange."
Is there going to be any problems making this work with the Sonex exhaust system?
Michael Crowder
Sonex #293
| - The Matronics JabiruEngine-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
Jim McCormick
Posted: Mon Mar 19, 2007 8:24 pm Post subject: EGT Probes on J3300 and Sonex |
Hi Mike
If possible mount your egt probes 4" down the exhaust pipe from the head.
If 4" is not possible I feel the next most important thing is that all the
probes are the same distance down the exhaust pipe from the head to get
equal readings on your gauge. Grand Rapids said if you can mount the probes
2" to 8" from the head and will work just fine.
Hope this helps you out.
Jim McCormick
Jabiru Pacific LLC
255 W Fallbrook 202B
Fresno, Ca 93711
Ph. 559-431-1701
Fax 559-277-3231
Web www.jabirupacific.com
Email Info(at)jabirupacific.com
