HS ribs
LIKE2LOOP(at)aol.com
PostPosted: Fri Feb 03, 2006 8:41 am    Post subject: HS ribs Reply with quote
In a message dated 2/3/2006 10:46:43 AM Eastern Standard Time, indigoonlatigo(at)msn.com writes:
The problem was much worse on the HS.  This stuff drove me, the dentist crazy.
    I found the HS nose ribs needed a little adjustment to follow the contour of the pre-bent skins. The 3 prong vice grip pliers do fine or pressing the corner of the rib against the wood work bench to add some curve to the very front edge of the flange and retrying the part helped it sit passively in contact with the skin.   Obviously the nose ribs do very little, as they are spaced so far apart. The biggest concern is to avoid the very front part of the nose rib flange from damaging the skin contour.
 (As a dentist, this was a simple adjustment to make...) sorry i couldnt resist.
Steve
Stephen G. Blank,DDS
RV-10  #40499            ALmost ready to Rivet the HS
Cessna 170b Flyer
Port St Lucie, FL
772-475-5556 cell
PostPosted: Fri Feb 03, 2006 12:22 pm    Post subject: HS ribs Reply with quote
I was not speaking of a lateral interference. What I am speaking of is more
like the concept of creating voids and trapping air bubbles in the corners
of your composite filling because the composite you are using is so stiff
that it cannot adapt to the shape of the preparation. In macro composite
construction, that is why we use a mix of light cotton flox and microballons
in the corners before we put the glass down. Micro composites, Flowables.
Believe it or not I believe most all the principles of physics apply
regardless of the size and medium one works with.
Just want to confirm we are on the same page. The corners were radiused in
addition to the bonding.
See Crazy right!.
JOhn
Reply-To: rv10-list(at)matronics.com
Subject: Re: HS ribs
Date: Fri, 3 Feb 2006 11:40:21 EST
crazy.
contour
contact
nose
resist.
Steve
Cessna 170b Flyer
Port St Lucie, FL
772-475-5556 cell
